Question about Trust GM-2500 Joystick
Just doesn't work
It is a recognized device and the movement/keys register in the test but i don't know how to get it to work ingame or assign the keys/movements
Tax Rate Button
That is the correct program it seems your program is corrupt, just wipe out everything and start afresh
May 11, 2013 | Casio PCR-T2000 Cash Register
My computer will not recognize apple products
Do a system recovery to a date the system worked ok. The system recovery is in programs then click Accessories then under the tool menu.
Apr 13, 2017 | Audio Players & Recorders
NUMBER 6 DOESN'T WORK
One possible cause is the bezel under the actual button is decompressed and wont pop back up. If the laptop has one, that means the little rubber like devider between the keys and the actual board that registers the key press is comopressed. You can pop off the 6 key and clean under it as well as visually check it out. you may want to remove the keys around it as well to see any issues. If you can't get it working, an easy work around is to assign one of your function keys(F1 thru F12) to the number 6. Kinda sucks but it will work until you get it fixed up.
Sep 23, 2012 | Computers & Internet
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Apr 28, 2017 | ASUS N73SV PC Notebook
NOT ASSIGNED CODE
NOT ASSIGNED means no cashier is signed on. Find the cashier number button, probably labeled CASH #. In REG mode, press CL to clear the error, then 1, then CASH #, and Cashier 1 will be assigned. The display will show -01- Go straight from here into your sale.
Some registers are set up to not show the cashier number on the display or receipt. If 1 CASH # doesn't work, try CASH #, 1, CASH #.
Most users don't track sales by cashiers, so they forget they even have the capability, and they forget how to use that CASH # key. If you press the CASH # button without entering a number, it will sign out the active cashier, and you'll get this NOT ASSIGNED error.
Jan 23, 2012 | Sharp XE-A402 Electronic Cash Register
I have a condre 1 to 1 my drives don't recognize each other
Hi sadafu,
Kindly double check if you have assigned the Master and Secondary Slave properly.
This must be the reason why your PC don't recognize your devices.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 29, 2011 | Computers & Internet
I have 94 cutlass supreme i don't know whats the problem with its starter. It turns on when ever if wants to and most times it doesn'y work. Can someone help me?
whenever it wants? Bad karma! Seriously, check your connections to the starter and the solenoid on the starter. That's the big (battery) cable to starter, and the small wire (purple, I think) on the solenoid thats on the starter. If they are tight and clean, you could check if 12 volts are registering at the starter with the key on (engine off. just turn key on.), or, just take off your starter and have it tested at like, Autozone. See, Jose? its either your starter or the connections to it. Sometimes a bad ignition switch will cause a no-crank situation, but if your dash lights come on when you turn key on, it's likely your starter. If starter and solenoid are o.k. you'll have to get your starting circuit diagnosed. I'd bet on the starter or solenoid,though.
Oct 07, 2011 | 1994 Oldsmobile Cutlass Supreme
I have a WD 1.5 TB My book 3.0. I have it for a couple of weeks, but now all of the sudden the PC(s) doesn't recognize the device anymore. Device manager does display the right hardware, and says it...
Try this. Download a program called discovery from WD, it is free. When installed, plug in the drive and run the discovery program. Your drive should work properly. Please let me know how it works for you.
Sep 19, 2011 | Western Digital My Book Essential Edition...
My notebook mic not working OS window XP
Let's try testing with XP's built in tool. Please follow the steps below.
1. Click 'Start' > Select 'Control Panel' > Double-click 'Sounds and Audio Devices'2. Select the 'Voice Tab' > Under Default Device what device do you see? > Click 'Test Hardware'If you don't get sound, change your Default Device that I mentioned above, the setting could be wrong.
Please let us know if this does or doesn't help to resolve your problem.cell phone cases ON TOPONS.
Aug 15, 2011 | Compaq Presario 700 470024-192 Notebook
Casio TK7000 Cash Register. I have all sales appearing as CAID and none in CHID or CKID or CRID. I have checked that Program 3 Address code 08 is set correctly. What else could be affecting this?
If the sale is finalized correctly, cash, check, etc., then cash in drawer, credit in drawer, etc. should show up.
If you don't have the cash, check, credit buttons, you can program them in like this:
PGM, then 4, followed by the desired Function Key Code, and then press the Key to assign this function to, followed by pressing the Subtotal button to save.
FUNCTION - CODE - CHARACTER
Cash Amount Tendered - 001 - CASH
Charge - 002 - CHARGE
Check Tender - 003 - CHECK
Refer to the following PDF document for assigning function keys, and a list of the function codes:
http://www.4shared.com/document/2poxz4Z8/Casio_TK-7000_Key_Allocation.html
If you need a User's Manual for this Cash Register, here it is:
http://www.4shared.com/document/2YONddyN/Casio_TK-7000_Users_Manual.html
Jun 06, 2011 | Casio Parts Cash Register PC Desktop
Trust GM-2500 Joystick Logo
41 people viewed this question
Top Trust Video Game Consoles & Games Experts
James Wishart
Are you a Trust Video Game Console and Game Expert? Answer questions, earn points and help others
