Question about GE Monogram ZIR36NMRH Refrigerator
Hi, my gm side by side refrigerator is not getting cold. The light will not come on in the refrigerator. The freezer ask like a refrigerator now. It doesn't freeze but stays cold. There is ice
textonor
  • 130 Answers
SOURCE: Freezer not freezing enough and fridge not cold enough
Hello Scott, remove the food from the freezer side and remove the rear freezer panel. You will see a coil and it should be completely frosted over. If not then you have a sealed system issue. If it is froze solid in frost where you cannot even see the coil, then you have a defrost issue. You should have a little frost on all the coil, the defrost is what clears the frost so the evap fan motor can circulate the air thru out the unit. If frost is good, push the light door switch to start the fan. If it isn't running check for 120 volts. If it has voltage, but not running, replace the motor. Hope this helps.
Posted on Aug 10, 2008
SOURCE: GE GSS 22KG SIDE BY SIDE REFRIGERATOR 6 YEARS OLD
The codensor fan is not running. I have the same problem. I had the fan replaced a year ago for the same problem, so I can't tbelieve it's the fan. I am guessing something on the circuit board is not letting the fan kick on. I don't have a definite answer yet, but the fan not running is the main issue you are having.
Posted on Sep 30, 2008
  • 1214 Answers
SOURCE: Freezer is cool but not freezing or making ice - fridge not cold
If there is frost on the back wall of the freezer, then the compressor is running. Another (maybe) good thing is the fan is running.
The problem could be -
1) Bad defrost heater
2) Failed defrost sensor
3) Failed defrost timer or refrigerator controller board.
There are diagnostic tests to determine the problem, but require skill at using a multimeter and possibly reading a schematic/wiring diagram.
You can temporarily make the refrigerator run again for awhile by unplugging, opening the doors, and defrosting for 6-8 hours (store food in coolers.). Then plug it back in. Note, water may come out of the freezer as a result of defrosted ice.
Posted on Jan 15, 2009
SOURCE: Side X side TFX20JA refrigerator not freezing or maintaining cold
Thank you for your help!! I was able to repair my refrigerater thanks to someone who had previously had the sam problem and was given three things to check. The problem was the heater in the freezer was burn out.
Posted on Feb 04, 2009
SOURCE: not cooling or freezing
bimetal switch not working. change it.
Posted on Aug 02, 2009
The freezer side is cold however no cold air flow is going to the refrigerator side
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 29, 2011 | Kenmore Side by Side Refrigerator
Refrigerator is not getting cold freezer is
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator not working, lights arem out. The freezer is working lights are on.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Dec 26, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Freezer side is cold but other side is not getting cold
heatman101
Nov 27, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refridge. light went out. Bulb is good. Indicator
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer side cold, other side not cold, temp settings ok set to 33f
heatman101
Nov 10, 2010 | Frigidaire FRS-26DR7D Side by Side...
Freezer side gets cold but the refrigerator side does not
heatman101
Oct 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
MY refrigerator is running but is not getting cold.
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Oct 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
GE Monogram ZIR36NMRH Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
