Schematic for a infinity il100s subwoofer
Need to know how to wire power switch
  • 905 Answers
SOURCE: Power Never Comes on
that remote wire has to be hooked up to the power or the radio power antenna wire which will switch the remote wire on when the radio is turned on, so that remote wire really should be hooked to the radio wire that gets power when the radio is turned on , thats why the sub is not turning on
electech
Posted on Oct 26, 2008
  • 27 Answers
SOURCE: Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
a single male rca spliting into 2 male rca's ....a signal splitter
Posted on Oct 30, 2008
  • 27 Answers
SOURCE: AMPLIFIER WIRING SCHEMATIC 2006 VOLKSWAGON TOUAREG
the12volt.com will tell you everyting you need
Posted on Feb 02, 2009
MrScary66613
  • 1990 Answers
SOURCE: Infinity Interlude IL120s Powered Subwoofer (home) will not power
Some of these Infinity Amps have an Internal Glass Fuse. Open the Case and Check for this Fuse. Please Rate My Response! Thanks!
Posted on Feb 03, 2009
  • 832 Answers
SOURCE: Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Posted on Jan 06, 2010
How do i fix my infinity entra 10 inch 150 watt powered subwoofer. fuse is good, green led is on so it is getting power
Best to start at the beginning. You have it connected properly? Are you using the line level, direct or speaker inputs? What output on your receiver are you using?
Have you adjusted the volume control?
If you have everything correct, are you the original owner? It's an older model so if you are the original owner what happened when it stopped working? Noises, fade out, just wouldn't turn on one day.
Are you capable of doing some minor electrical work? Can you read a schematic? Can you recognise electrical parts? If the answer to any of these last three questions is no, you need to take it to someone that has the ability to do electrical repairs. If the answer to all three is yes you can fix this yourself.
Feb 08, 2016 | Infinity Entra Sub Subwoofer
No power getting to infinity interlude il100s
you have a nasty short cercuit in your woofer box due to constant mooving around or pulling the cords so get it fixed befor it costs you a lot more muney
Jan 12, 2014 | Infinity Audio Players & Recorders
I need the wires to conect my infinity basslink 10''
Any auto parts store or WalMart will sell adequate speaker wires. For a sub of this power rating, you'll be fine with 14GA speaker wires (pronounced 14 gauge) but if you want to get beefier wires in case you upgrade the sub later, I'd recommend this 10GA hookup kit or something comparable.
Feb 13, 2010 | Car Audio & Video
1998 Toyota Camry Le Wiring Diagram. i want to hook a subwoofer with stock stereo. Need to know what to use so it will power off when car is turned off.
Hello motoxbear17,
You do not specify what particular amp or powered subwoofer you intend to install, so I'm assuming that you have an amp that uses a remote 12V+ signal to turn the amp on and off. Some powered subwoofer systems like the Bazookas, Infinity Basslink, and MTX Thunderlink use an "audio sensing" circuit that turns the sub on only when the radio is on. Some amps also have such a "turn-on" circuit that is active when speaker level inputs are used. I'd recommend that you check the documentation that came with your amp and see if it has such a feature.
For a normal subwoofer amp with power, ground, and remote terminals, the remote terminal usually just needs a 12V+ source to turn the amp on.
In your vehicle, the gray wire coming from the receiver harness is a 12V+ switched source.
Here's a link to the '98 Camry wiring color code:
http://www.modifiedlife.com/car-stereo-radio-wiring-diagram-1998-toyota-camry/
With this connection, the amp will power on whenever the vehicle ignition is on or in accessory, regardless of whether the radio is on or off. If this is objectionable, you can simply add a SPST toggle switch inline with the lead and turn it on only when needed.
Hope this helps.
Oct 18, 2009 | Car Audio & Video
Burns [blows out the 50v bridge rect] on power up. cant find the short??? all conds and resistors seem to check out OK ??? The four Z-diodes seem ok also ??? All transistors seem ok [no low ohms-only...
I'd suspect the 6800uF caps, but I don't know for sure.
If it helps, here are the schematics for the upper and lower boards:
Upper board
Lower board
I wrote to KLH to ask for them, and explicitly asked for permission to post them here.
Jun 15, 2009 | KLH ASW10-120 Subwoofer
Infinity Bass link has no power. Both fuses are
what the problem is that you have a bad ground one way to tell is run the ground to your battery ground and i bet you it will work it happens all the time
Apr 17, 2009 | Infinity BASSLINK Car Subwoofer
Need to wire it up in gm car . infiniti g35 sedan seats
You would need to find a wiring schematic for the seats or for an interior harness for a G35 to see with wire is power, ground and so forth... then you would run accessory power through an inline fuse to the power ground the wiring to either a good ground on the floor or an existing ground and your set
Mar 08, 2009 | 2007 Infiniti G35 Sedan Sport Sedan
Feb 03, 2009 | Infinity 7540A Car Audio Amplifier
electech
Oct 26, 2008 | Infinity BASSLINK Car Subwoofer
10 pin plug wiring configuration
7e83231.jpgI had the same problem.  Here is the picture I used.
Oct 05, 2007 | Kenwood KSC-WA82RC Car Subwoofer
133 people viewed this question
 Grubhead
Grubhead
