Question about Sony PlayStation 2 (PS2) Console
Ps2 keeps shutting off
Just replaced the laser for a new one, the problem i have now is when i shut the lid the system turns off.
    Scholar:
  • 39 Answers
Hi loonyhouse ! It sounds pretty odd. You should take the ps2 apart, and harden any flat cable or cable connection in the ps2. It sounds like a looose connection, or a loose screw creating a short in it ? It's just a physical problem most likely. Take it apart, i'm sure you'll find it.. it NEEDS to be obvious :) Thanks, cheebster.
Posted on Jul 11, 2007
SOURCE:
My son tripped over our friends ps2 and it fell to the floor upside down. The PS2 goes but the drive does not go.Any ideas how to fix this problem" Thanks
There are quite a few things that can cause a disc read error on the slim PS2. The most frequent is a bad laser, however, here is some useful troubleshooting info:
1. "Lid Closed Sensors" There are two "lid closed sensors" in the slim PS2. In a fall, it's possible that one or both have become damaged. Remove the top of the PS2 and try depressing both sensors with a game inside. The laser should move up and down at least???
IF YES, try again with the lid on... if the laser doesn't move when you close the lid, then the top casing of your PS2 cracked in the fall and is no longer depressing the lid closed sensors.
==> If the laser moves up and down OK but does not read discs, your laser was damaged in the fall. See below for a website with more troubleshooting info, pictures, and replacement cases and lasers.
http://store.richspsxparts.com/slpsnospdi1a.html
IF NO, you have a bad lid closed sensor -- these are not really replaceable easily -- you may be better off replacing the whole PS2 if one or both of these lid closed sensors goes bad.
Nov 17, 2009 | Sony PlayStation 2 Slimline Console
Ps2 slim will not spin disk i have cleaned everything inside everything seems to be working normally yet the disk wont spin
If you have removed the cover and cleaned the glass laser eye lens unit, then the laser lens motor is faulty.
Nov 10, 2009 | Sony PlayStation 2 Slimline Console
When after powering up and I had press enter, it would say CAN NOT READ DISC.
There are THREE reasons that a Slim PS2 will not read discs. I will start from most common and end at the least common (almost rare) problem.
1. A bad laser. Lasers labor on Playstation 2 [and all other video game] consoles. They eventually fail, especially if you use your PS2 as a DVD player. You can find Slim PS2 lasers at the following website. They are pretty simple to replace:
http://store.richspsxparts.com/v12laser.html
2. There are two "lid closed" sensors on the Slim Playstation 2. They let the PS2 know that the lid is shut and it should scan for a disc. Sometimes one or both of these sensors can become broken. It doesn't really happen by itself... usually if someone drops the console, one or both of the sensors can break or become dislodged.
3. A Bad Motherboard: This is rare. We mostly see this if someone installed a mod chip into the system and it eventually fails.
Click into the following website for Do It Yourself troubleshooting to determine why your PS2's discs aren't spinning, and how to fix it.
Playstation 2 slim will not read discs. disc inserted and door closed still nothing happens. no laser movement, nothing.
There are THREE reasons that a Slim PS2 will not read discs. I willstart from most common and end at the least common (almost rare)problem.
1. A bad laser. Lasers labor on Playstation 2 [and all other videogame] consoles. They eventually fail, especially if you use your PS2as a DVD player. You can find Slim PS2 lasers at the followingwebsite. They are pretty simple to replace:
2. There are two "lid closed" sensors on the Slim Playstation 2. Theylet the PS2 know that the lid is shut and it should scan for a disc. Sometimes one or both of these sensors can become broken. It doesn'treally happen by itself... usually if someone drops the console, one orboth of the sensors can break or become dislodged.
3. A Bad Motherboard: This is rare. We mostly see this if someoneinstalled a mod chip into the system and it eventually fails.
Click into the following website for Do It Yourself troubleshooting todetermine why your PS2's discs aren't spinning, and how to fix it.
Nov 07, 2009 | Sony PlayStation 2 Slimline Console
Rock band wont work keeps saying no data disc can not be read
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER
Dec 25, 2008 | MTV Games Rock Band for PlayStation 2
Ps2 drive failure in slim models
My PS2 has been played so long, let those PS2's run for a minute, usually it takes a minute or two kicking on for those, I have one that takes a while to kick on. If that doesn't work then you just can't do anything, sounds like something is just messed up, when I have a spare PS2 i'll drop it and see what happens for you.
Dec 04, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 not able to read disk
Hi this is the commonist fault on all ps2 and even ps3 their is no way of repairing the laser itself the only option you have is to replace the laser unit the problem with doing this is that if you buy a new laser you will need to get it calibrated and to do this you will need oscilscope and these cost about £300 or if in us about $600 so thats the problem of buying new ones its often cheaper to buy new ps2 than go down that route.
The other option is buying second hand ps2 of an auction site but the problem with this also is that it might have same problem as yours.
What i did that made mine work for few months extra was to use ask.com and type in :Disk read error on ps2
or try this How to repair ps2 disk error or just try repairing ps2
On doing this i came across a site but i cant remember what it was called but this site showed you step by step instruction on how to adjust the laser slightly so that it played games again after following these instructions mine worked again for about three months.
It basically told you to remove the case off the ps2 then where the laser is its like a black plate but you cant see the laser remove this black case i think their was about two little black screw on the top of the black lid covering the laser it covers the disk so you cant see the disk with case removed.
Anyway remove this black lid then if you look at the back of the laser tray not at front where the game goes in but towards the back their is a white disk about the size of a coin now this site told me to first mark with marker the white disk so you know where you started from put line on the white disk then on something else but not the disk so you know where it was located before you turn it doing this lets you go back to how it was before you moved it.
After doing this if you turn the disk slightly it raises and lowers the laser lense now you need to do this a bit at a time and then but the black lid back on with screws then try a game in it you can hold the black lid ontop of the laser unit if you want but dont push to hard and dont hold it to soft else game wont spin properly.
Just turn this white disk a bit at a time then try loading a game keep doing this you can turn it either way if your lucky you might find that adjusting the laser hight might get it working again if not then the laser needs replacing but remember if it dont work then you need to turn the whit disk back to where it started from ie where you marked because if you replace the laser this white disk needs to be back where it was originally.
If you are going to do this search the net first you should find the complete instructions on doing this ok also make sure you dont shine the laser in your eyes or other peoples eyes as its dangerous and can blind you in the future so make sure the case is on the laser before its switched on.
If you cant find the site let me know and ill have a look for you ok also let me know if you need further assistance
Feb 01, 2008 | Sony PlayStation 2 Slimline Console
PS2 will not play games
the games are fine it is the system. it needs a cleaning. if it trys to read it it needs to be cleaned. if it trys to read it and it says error/ cannot read then the laser needs to be adjusted. if it just does not do anything, you need your laser replaced. send it in to a game system repair center. connie
Jun 28, 2007 | Sony PlayStation Portable (PSP) Console
Cdrom won't spin
HI THIS PROBLEM IS USUALY CAUSED WHEN LID IS PUT BACK ON .. THERE IS SOME LITTLE SWITCHERS ON THE PS2 NEAR THE LASER THESE SWITCHERS ARE TO TELL PS2 WHEN LID AS BEEN OPENED AND A ANTI PIRACY PROTECTION FOR DISK SWOPPING PICS SHOW WERE THE LITTLE SWITCHERS ARE ..__TRY TAKING THE LID BACK OFF AND PLACING LID BACK ON WITH LID TRAY SHUT AND IF THAT DOES NOT WORK CLOSE WITH LID OPEN AND AT THE FRONT WERE YOU PRESS THE BUTTON TO TURN POWER ON CHECK IF THE LITTLE SWITCH AS COME AWAY OR BROKE IF SO I SELL REPLACMENTS MY WEBSITE IS WWW.CONSOLEREPAIRANDPLAY.CO.UK
May 23, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
254 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
