Question about Caterpillar Backhoe Tractor
I have a Caterpillar 939C hi lift...I have no power to the ignition. I bypassed the kill switch but no use. Replace the batteries still no power.
I checked the Main breaker and it is not tripped and also checked all the fuses. I have not been able to find a wiring schematic for my particular model short of going to caterpillar which wants an arm and a leg.
  • 4 Answers
SOURCE: Caterpillar 426c Problem will not shift Into
Transmission control valve is the problem. If it has the original plastic shift spools, they need to be replaced. Also, before you do anything, cut open the transmission & look for metal. If that's ok, then remove the plastic transmission shift spools & replace them with metal ones.
Posted on Apr 23, 2010
  • 248 Answers
SOURCE: Caterpillar 50 Fork Lift truck - yr 2002 suddenly stopped motion
check the safety switch under the seat may have been pulled loose or switch may be bad
Posted on Oct 06, 2010
SOURCE: have a mitsubishi caterpillar forklift model
error message E-27
Posted on Mar 31, 2011
SOURCE: I need tracks for my Caterpillar Construction Set
I need a set of tracks if anyone knows where to find them.
Posted on Feb 26, 2012
SOURCE: service manual th62
You can buy an OEM Caterpillar service manual from www.SerivceManualPro.com
Posted on Mar 10, 2013
Truck will not crank. Previous owner installed crappy kill switch that initially started the problem.I by pass it and truck was running fine. Till the a ground cable came loose on the battery. There's...
It would be the ignition or those ignition wires because of the kill switch being poorly installed, id try tracing wires first and replace anything thats been cut/spliced into. if not change the ignition
May 12, 2011 | 1992 Toyota Pickup
1997 Polaris rmk 700 has no spark. Kill switch is in run position and key is on. Sled ran fine last year. I get a little tail light when I pull starter rope
try bypassing the kill switch and the ignition switch. Often the switches fail before the other components. the ignition can usually be bypasses by simply unplugging it from the harness. You may have to loop the wires to bypass the kill switch.
Jan 22, 2011 | Polaris New Genuine Polaris Snowmobile...
I have no spark on my 94 ext and it has a new stator and cdi box and igntion coil
Bypass your ignition switch , kill switch, and carburetor safety switches(on the side of the carburetors). All common problems for older sleds (stopping spark). In the carburetors the magnets inside the slides come off killing the spark. There is a kill switch bypass wire in most arctic tool kits. Ignition switches are notorious for going bad and are easily bypassed by simply unplugging them.
Jan 16, 2011 | Interactive Toy Concepts Crossfire Arctic...
1983 yamaha xj 650 no spark already changed the cdi coil plugs wires and mag pick up what next?
  • Do you see spark? If not, check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the side stand kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it.
  • Is the handlebar kill switch on? Is it shorted out?
  • Are you getting power to the coils?
  • Check the fuses. How good is the battery? Try a jump start from your car battery.
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center or side casing. If still no spark, get CDI system and coils checked at the dealers shop.
Aug 06, 2009 | 1983 Yamaha XJ 650
No sparking on a 1979 YZ 125
Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Also check the wiring harness for loose and/or dirty connections. Look for bad plastic connecton blocks and abraided wires.
Jul 26, 2009 | 2003 Yamaha YZ 125
92 Cb250 Nighthawk won't start
Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter.
A “very helpful” rating for this answer? Thanks!
Jun 17, 2009 | 1992 Honda CB 250 Nighthawk
My gilera runner has nt got a spark i have changed the magneto flywheel spark plug but still no spark what could it be?
Jun 11, 2009 | 2005 Gilera Nexus 500
Caterpillar Backhoe Tractor Logo
50 people viewed this question
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
