Question about Gaggia Classic Espresso Machine
Lacks correct steam for milk froth - Gaggia Classic Espresso Machine
  • Gaggia Expert
  • 109 Answers
Requires cleanout and service,no quick fix
Posted on Jan 26, 2013
Noggin
  • 944 Answers
SOURCE: spout for frothing milk pops out
You can get the user manual on this link if you need it; http://www.gaggiaparos.co.uk/ Check page 6 of the download, page 12 of the manual - the spout should just pull off and push back on. If it wont, then either something needs cleaning more, something is stuck in the tube or more likely the part of the nozzle that comes off, something is broken, or you need to use a little bit more force. If it appears broken, (check in particular for a fine crack that is only visible when the nozzle is stretched i.e. when in place. This type of plastic often will close a crack enough to be near invisible when not under tension.) then you could try gluing it although i doubt if this would work. You could just put a stainless steel hose clamp around it, tighten up just enough to make the nozzle spout stay on (bit of a pain, but may work). You can contact gaggia for a replacement - in the USA; Importika 596 Fishers Station Dr. 14564, Victor, NY Mr. Salzman Ph. 585.742.5178 Fax 585.924.1499 web site: www.importika.com e-mail: sales@importika.com Hope this helps - if you can post back a photo or two close up of the problem area, i may have more ideas :)
Posted on Jul 05, 2007
  • 4 Answers
SOURCE: the message ventilate is showing
As pointed out by bansheracer, "Ventilate" means you need to open the valve on the right to let out some steam from the milk steamer wand. This can also happen if you accidentally push the 'steam' button but don't actually let out any steam.
If it is stuck or needs cleaning, unscrew the metal piece and dip the plastic bit in a jug of hot water - it should resolve most of the dried milk in about 5-10 minutes.
Posted on Oct 23, 2009
SOURCE: the steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Posted on Feb 14, 2010
Testimonial: "Thank you very much for the advice. I adjusted the black tube and the frothing is back!"
z34aga
  • 137 Answers
SOURCE: The steam wand emits a very thin and weak stream
Decalcification of coffee machines boilers is better to be done with special powder for decalcification in aluminum. For making the solution from the powder you must go by instructions of manufacturer of powder. Anyway you should clean the pipe too, you get glass of water and put pipe in, steam up until it boils, than you live it for 3-4 hours. Softened milk sedimentation's will come out easily if they are present.
Posted on Feb 25, 2011
Testimonial: "Great reply - short, concise, and completely to the point. Problem solved. Thankyou."
JohnnyBeans
  • 223 Answers
SOURCE: Hi, the steam from the wand is not frothing the
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues. http://www.cerinicoffee.com/rinza_urnex.asp
Also recommend frothing water instead of milk to clean the frother well.
For more information visit: http://www.cerinicoffee.com/Coffee_cleaning_supplies.asp
Posted on Jun 08, 2011
How do i use the steam wand to froth milk
The steam wand to froth milk, you need a certain amount of milk in the cup first, then if you tilt the cup a little towards you, push the steam button and "it should froth your milk right up", but if that doesn't work then I don't know.
Mar 24, 2014 | Bella Espresso Maker - Black
Froth
If you are getting steam out of the wand I suggest you practice and work ha and to learn how to froth up the milk. The machine does not froth up, it is the operator who does. You basically need to keep the wand just below the milk level and keep moving very slowly up and down always trying to stay below the milk level. If the container is wide you may need to swirl as you moving.
Mar 14, 2013 | Saeco Coffee Makers & Espresso Machines
My steamer wand has an awful odor everytime I try to steam something! I have cleaned it (even soaked in baking soda!) and the problem won't stop. Anyone else have this problem?
This is a common problem for the commercial espresso machines, Due to lack of cleaning of the steam wand after they finish frothing milk.
The milk flows back to the boiler and the water gets contaminated with milk.
Does the steam smells like rotten milk? If the answer is yes, you have contaminated water and or lines.
If not may be there is a lot of IRON in the water.
Run a descale cycle.
After you are done frothing milk, wipe the steam wand with a wet towel and open the steam valve for 2 seconds, close it and that's it.
Jan 15, 2011 | Saeco Starbucks Sirena Espresso Machine
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
The steam wand is bubbling the milk, not frothing
Feb 13, 2010 | Gaggia Titanium Espresso Machine
The mahine does not froth the milk properly anymore
alisha165,
the saeco royal digital dosn't froth milk.... it produces steam, you are the one that froths the milk. is the machine still producing steam? if not you will need to have your steam boiler replaced. This should only be dune by a qualified repairer. If it is still producing steam but it is not as good as it use to be, descalling you machine may help.
Sep 29, 2008 | Saeco Royal Digital Plus Coffee...
Seaco Odea Go
You can not adjust the amount of this.
/Mirran
Aug 17, 2008 | Saeco Odea Go
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Gaggia Classic Espresso Machine Logo
43 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
