Question about Emerson Evergrind E202 1/2 HP Garbage Disposer
My garbage disposer Evergrind E202 is leaking by the push botton constantly so I think it needs a gasket to be replaced
Garbage disposal quit working. Just stopped
Press reset button located on bottom of unit.
Use broomstick down inside disposal to make sure cutter disc rotates freely.
Copy following link for troubleshoot and illustrations:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
h
Aug 19, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
Leaking garbage disposal
1) Where is the leak coming from?
Copy following link for troubleshoot walk thru and replacement tips
2) Add a comment Feb 2013
Feb 10, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
It stopped spinning but the motor made a buzzng noise, then it just stopped all together, now nothing
1) Copy following link for troubleshoot tips and instructions how to install new disposal:
2) Once the motor stops spinning, it will begin to overheat, and that will trip the thermal reset button.
Push reset button located bottom of unit, then rotate disk with broomstick. If motor will not work, then replace unit.
Feb 05, 2013 | In-Sink-Erator InSinkErator Badger 1 1/3...
Badger 5 leaking from body middle connection
1) Copy following link for troubleshoot and parts resources, and manuals with warranty information:
2) New unit would be best solution. And possibly cheapest solution. Otherwise you might be installing and un-installing more than once or twice ... which is fun if you have time, and other housemates don't mind kitchen project tools, water and mess.
3) If you can disassemble the disposal, you might be able to make your own gasket using kits and sealant from local auto parts .... assuming the metal was not mis-cast during manufacture and is warped so it never seals.
Dec 12, 2012 | In-Sink-Erator InSinkErator Badger 5 1/2...
Emerson Evergrind E202 1/2 HP Garbage Disposer Logo
211 people viewed this question
Top Emerson Water Heaters Experts
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
