Question about Sewing Machines
How to install horizontal Hook Drive Gear, Singer #163997?
How do you replace the hook drive gear on a singer 132 featherweight sewing machine
pull the machine apart to get the shaft out
best take it to a sewing machine shop to have it done as it will be less trouble than you doing it
Jul 15, 2016 | Singer Sewing Machines
Singer sewing machine repair manual
Depending on model my first guess would be the gear from upper main shaft (horizontal) or the gear from Vertical shaft is broken
May 11, 2014 | Singer Sewing Machines
My needle is hitting the hook race when it lowers. It seems to be a going down a couple mm lower than it should be. I am using a Singer 9920. Any fixya tips out there?
Suggest that you check your needle to make sure it is lock fully up into the needle holder. If your needle is correctly installed, then it should be a needle/hook timing problem. Or if your rotary hook can be turn freely with your finger, it also indicates belting/gear problem. Do get your local technician to fix it.
Aug 20, 2013 | Singer Quantum 9920 Computerized Sewing...
My hook gear has gone bad, I have singer sewing machine model # 834, I need help with how to take the parts off and replace them
http://www.sewingpartsonline.com/singer-834-sewing-machine-parts.aspx
Follow this link, click on the hook gear parts, and you will see a link to a video showing how to install these gears. I was able to follow this video and replace the gears on my old machine. For me it was do-able, but moderately difficult. If you think you're up to it, go for it. Replacing all for gears a t once will cost $50. (Singer 834).
Sep 16, 2010 | Sewing Machines
Rotating Hook won't fully turn-Singer 2210
The nylon gear driving the hook has probably broken a tooth. Replacements are available if you search the web.
Make sure you get the matched set of driving gear and driven gear.
Apr 24, 2009 | Singer Sewing Machines
Replacing broken gears on Singer Touch & Sew Model 648
Remove the plastic faceplate from the front of the machine. There is a Singer logo button that you will have to pop out to release it, and then the lever nobs to get around to get it off. You can then access the allen screw on the top gear.
Remove all the set screws on both the top and bottom gears on the vertical shaft. Put them in a safe place.
The vertical shaft sits directly below the horizontal shaft, but there is some space between them and wiggle room to do the following. If the shaft does not slip down easily, use a small diameter rod or screwdriver to gently tap the vertical shaft downward until the top gear slips off the end. Remove the gear.
Mar 09, 2009 | Singer Sewing Machines
Timing on Singer 507 after replacing stripped drive cogs
Contact Singer by phone or by: Singer sewing machines.com thay should be able to assist.
Jan 05, 2009 | Singer 5070 Mechanical Sewing Machine
Quit working
The 132Q ahs a problem in the hook drive gear ,this is where it is seized up ,happens all the time ,from the back of the machine you can add lubricant to the hook gear and shaft but you will probably have to grab the gear with pliers etc and try to turn it once it loosens up it will be fine ,do not look elsewhere this hook drive shaft is the source of the problem.
Dec 07, 2008 | Singer Featherweight 132Q Mechanical...
Singer 1725
The hook drive gear is seized and requires lubricant ,this is the gear right behind your bobbin case I believe you can access it from the rear ,I hope this helps
Nov 29, 2008 | Singer 1725
Sewing Machines Logo
63 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
