Question about Texas Instruments TI-5630 Calculator
What size paper roll does the TI-5630 use?
I need to order the paper for the TI-5630 for a member of my company, but we have no idea what size to use. Are you able to help? Please?
Ti-5630 how do I clear the E on the display
I had the same error. TI support helped me fix it. Power off the machine. Press and hold the MT key while powering the machine back on. Ta da!
Mar 13, 2014 | Texas Instruments TI-5630 Calculator
What size paper roll is used for TI 5045sv? Can't seem to find it anywhere!
Standard 2-1/4 inch wide plain paper single copy calculator paper rolls, available at Office Depot, Reliable Office Supplies, and many other office supply stores and catalogs. Probably have them at Staples, too.
Mar 24, 2013 | Texas Instruments TI-5045 SVC Calculator
How do I get a new cartridge to print?
Here are a couple of online stores that you can order replacement print cartridges from:
http://www.heasterlawson.com/texintielcal1.html
http://actioncomputer.stores.yahoo.net/ti5151525682.html
Either of the sites will sell you the replacement cartridges. IF you are having problems loading the cartridge and getting it to print this link will take you to a website that will let you download a copy of the users manual:
http://www.retrevo.com/support/TI-TI-5630-Calculators-manual/id/426ci766/t/2/
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 18, 2011 | Texas Instruments TI-5630 Calculator
HOW DO I LOAD THE PAPER?
Try the instructions in the first few pages of this document:
http://education.ti.com/downloads/guidebooks/printer/5630/5630.pdf
Oct 13, 2010 | Texas Instruments TI-5630 Calculator
On the scanner and the plotter there is a exclamation point after the 24'' paper. The 24'' paper will not print, but all other paper does. any idea what the ! point means and is there an easy solution to...
It means that the paper is not available. A smaller size paper could have been loaded in the place of 24" roll, the plotter could have more paper trays/rolls configured than are actually installed, or the paper may not be what it says it is.
May 05, 2010 | Office Equipment & Supplies
Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
Sep 26, 2009 | Sharp EL-1197PIII Calculator
How do I graph ordered pairs on a TI 86 plus?
Use the stat menu. Enter 1st member of a pair in List1, Enter 2nd member of pair in List2. Graph the data as a scatter plot in stats plots.
Hope it helps.
Jan 15, 2009 | Texas Instruments TI-86 Calculator
Paper size
I use Esselte Dataline 210x30x12.7, the code is 80428 and the last lot I bought cost me £2.99 but I am afraid it is quite a whilst since I purchase this thermal fax paper I cannot remember where I bought it from, but I hope this helps
Dec 12, 2008 | Brother FAX-525DT
Texas Instruments TI-5032SVC
it loads in the back right under the paper roll. it just looks like a gap in the casing but it is not. it's very important
Jul 20, 2008 | Texas Instruments TI-5032 SVC Calculator
Texas Instruments TI-5630 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
