Question about Dell W5001C 50 in. Plasma HDTV
No picture or sound but it is on
The dell splash screen doesn't come on and i can see it is on but no picture or sound.
  • 1 more comment
  • rdnckgurl Jan 29, 2009
    how hard is that to do and what about prices for parts.
    I tried turning it on today and the dell screen came on flickered a couple times and went back to the dark grainy screen. Wonder about part numbers too lol. Thanks for the reply
    Oh and yes the power light is blue.. I had wondered about the y mainboard i am seeing posted
  • wags7879 Feb 28, 2009
    Were you able to fix your TV? I have the exact same problem on the exact same model and of course receive no help from Dell.
I have a 50in plasma that just went out the other day the tv comes on but without pic and sound how can i fix it
Posted on Jan 13, 2010
    Problem Solver:
  • 16 Answers
I REPLACED THE TWO 2200UF CAPS ON THE POWER SUPPLY MAIN BOARD . BOTH THE BAD CAPS WERE BULGING AT THE TOP. I COULDN'T FIND DIRECT REPLACEMENTS SO I USE ONE 4700UF AT A HIGHER VOLTAGE RATING FROM RADIO SHACK AND FIT IT IN OVER THE BOARD. JUST MAKE SURE YOU INSULATE THE LONG LEADS.
Posted on Oct 01, 2010
  • nolimits27m Apr 27, 2011
    You can increase the temperature rating or the voltage, but increasing the uf rating will cause major issues most often immediately, but if not immediately, shortly after. Changing the uf rating, changes the entire character profile of the cap. You should have ordered the correct caps from a specialized electronic components supplier, not settled for what radio shack has, which is primarily cell phones now a days.
  • TJ Noffy Jan 15, 2012
    I replaced these same two caps with the proper 2200 uF caps and the set works now. See this article for which caps i replaced:http://blog.coppelltvrepair.com/2010/10/...
    I had no picture and no audio, but power button lit up blue when pushed and relay clicked. Set did not respond to remote, such as power on/off. These caps are in the low voltage part of the power supply that provide power (e.g. 5v) to the logic board. My 5v reading from the power supply was 3v-3.5v, apparently low enough to prevent the set from powering the picture, audio and remote control circuitry.
  • 4 Answers
Have a look at this instructable:
http://www.instructables.com/id/Dell-W5001C-50quot-plasma-fix/
It describes fixing a W5001C with the problem of a blank screen but still having audio.
Posted on Apr 17, 2009
Also check out coppell tv repair http://blog.coppelltvrepair.com/2010/10/dell-w4201c-hd-powers-on-off-no-picture.html
They have a parts kit for a common power supply failure for several Dell HDTV including the W5001C Look for bulging capacitors on all circuit boards and replace with the same UF (microfarad). However it is better to replace them with a higher voltage and tempature rating if you can find ones that fit on the board and chassis. Use an ESR meter to find the bad caps that are not bulging at the top. You do not need to unsolder the caps to test them with the meter. Electrolytic Capacitors are the most common failure in all modern consumer electronics and they are cheap to replace. It is because they are organic and dry out over time. Faster in hot environments like sandwiched between 2 large heat-sinks in the power supply section of the circuit board of a large screen plasma tube as in this TV.
Posted on Jul 08, 2011
    New Friend:
  • 90 Answers
As long as the power light is blue, its probably the panel and the audio amp. because these units are old, i simply replace the panel, powerboard, this usually solves the problem along with the updated rev code and firmware update.
Posted on Jan 29, 2009
  • Jim D Nov 21, 2010
    You really dont know what you are talking about
Dell Inspiron 6400 doesn't boot past dell splash
The hard drive has failed, or windows 7 is not compatable with the laptop. Try installing vista, if this works! there is a problem with windows 7, no change! have the hardware checked for possible replacement.
Jul 01, 2012 | Dell Inspiron 6400 Notebook
My 531S hangs at the dell splash screen with one short beep before loading windows vista
I would start the computer in safe mode. To do this, keep tapping on the F8 key as you start the computer. Do this as soon as you see anything on the screen. If you get the windows splash screen, you've waited too long. Once you get the white menu on a black screen, choose safe mode and let it start. The next time you do a restart, it should work. If it doesn't, then in safe mode do a system restore back to the time it worked.
Apr 06, 2012 | Dell I531S-2809 PC Desktop
Dell Optiplex gX520 will not boot beyond the splash screen. Dell Optiplex gX520 will not boot beyond the splash screen. There are not post code beeps.The lights on the front panel are 1 and 4. Both are...
Sounds like you may have multiple problems. Suggest trying to eliminate possible causes by removing components. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Remove the components one at a time and see if the LED's change.
Dec 10, 2011 | Dell Optiplex GX520 Desktop PC - Intel...
Disable dell startup splash screen to see RAID console
most likely, RAID is disabled. Restart the computer, tap F2 as soon as the computer starts until it takes you to the BIOS screen. Look on the Drives section and verify if your SATA or SATA OPERATIONS are set to RAID ON. Save the changes.
Afterwards, restart the computer and see if it works. Note, when it displays the Dell Splash screen, you may try to hit CTRL + i or CTRL + N to enter the RAID BIOS.
If none works, you can also visit http://support.dell.com and go to the Drivers and Downloads page. Enter your Service Tag or select your system model. Then check for an available update that you can download and install for the BIOS and Chipset of your computer.
cheers,
rodietom
Dec 10, 2011 | Dell Inspiron 570 PC Desktop
Dell Dimension 4300 desktop screen goes black after windows splash screen appears. Have reseated RAM.
After hitting the power button on your computer, throw it into "BOOT MODE" and select your hard drive. See if this helps your computer load. If so, you will have to go into your BIOS Setup and make your current hard drive your Primary Boot Device.
If this doesn't help, load your restore disc and check your drive for errors.
Your problem shouldn't be anything more than a few registry errors OR a boot problem.
Sep 09, 2011 | Dell Dimension 4300 PC Desktop
On startup my dell 8300 only has a black screen no splash screen cannot start in safe mode diagnostic lights abc are green d is amber your Black screen Problem
If you are not getting any Video at all, No Dell SPlash screen, nothing, then I'd look at a video card as the 1st point of Failure.
If you Get a Dell Splash screen, but nothing afterward, then the hard drive is suspect
Jul 08, 2009 | Dell Dimension 8300 PC Desktop
The TV turns on; there is no picture or sound
your mainboard needs replaced from within you engine component located in the rear part of the unit. its the boad with the most inputs. google the board id and see if u can find a replacement.
Jan 09, 2009 | Dell W3706MC 37 in. LCD HDTV
Dell pp01l
Using the Fn key combinations..
Fn> + <End>
Mutes the speaker
<Fn> + <Page Up>
Raises the sound volume
<Fn> + <Page Down>
Lowers the sound volume
<Fn> + <F10>
Ejects the drive bay
<Fn> + <Esc>
Places the computer in Suspend Mode
<Fn> + <F7>
Alters the font size at boot. If the Dell splash screen or Windows splash screen is very small, then this will enlarge it.
<Fn> + <Down Arrow>
Dims the backlight on the LCD
<Fn> + <Up Arrow>
Brightens the backlight on the LCD
Jan 16, 2008 | Dell LATITUDE C640, P4...
Dell W5001C 50 in. Plasma HDTV Logo
1,740 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
