Question about Lenovo 46r1842 - Thinkcentre M57 Core 2 Duo System Board Wo Cpu
PCI serial port driver - Lenovo 46r1842 - Thinkcentre M57 Core 2 Duo System Board Wo Cpu
PCI Serial Port driver missing
here is your missing driver just download it and install it hp dc7600 pci serial port driver
Sep 22, 2013 | Joy HP DC7600 Refurbished Desktop PC
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Need drivers for PCI-E expresscard 1/0 adapter
Go to www.drivers-download.com and search for DL-0254103 from "Drivers Search". Or you can use an alternate site: www.prolific.com.tw Use this path: Download >> USB to Port Controllers I/O >> PL-2303 Software and Drivers.
Jun 22, 2012 | Port Designs Best Connectivity RS-232...
I recently downgraded from Win7 to XP i got all the drivers installed but when i check Device Manager there are 2 device with Yellow question marks namely: PCI Device and PCI Serial Port ive check on the...
The "PCI Device" and the "PCI Serial Port" could be a modem that lacks the device-drivers.
Access: http://WindowsUpdate.Microsoft.com and do a "custom" search.
When it completes, click "optional hardware updates", to see if Windows Update is offering any device-drivers for your hardware.
Feb 21, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
How to Install a PCI Serial Port on an HP Compaq dc7700p small form factor
That "PCI Serial Port" is probably part of a PCI modem that is connected into a PCI slot on the motherboard.
Access the manufacturer's web-site: http://support.hp.com
and enter 'dc7700p' and do a search for device-drivers for your computer.
Download the device-driver. Install it.
Feb 17, 2011 | HP Compaq dc7700p PC Desktop
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Need drivers which support pci Serial port for my Dell GX270. Where can I get these?
Depending on the hardware that you have, either Windows will recognize your device and install default drivers or you will utilize the installation software that came with your device.
Can you provide the brand and model for your Serial PCI card?
May 15, 2010 | Dell OptiPlex GX270 PC Desktop
Lost install instructions for Hi-speed usb 2.0 5-port PCI card.
The drivers are here. You shouldn't need to do anything to install the card other than plug it into a PCI slot in your computer and install the drivers.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
How can I add dual serial pci multi I/O card to my dell 2400 pc?
You can install a dual port pci serial card if you have a free pci slot on your motherboard. This one is from Tigerdirect.
Jan 27, 2009 | Dell Dimension 2400 PC Desktop
Keyspan SX Pro Serial Adapter set up
Do you have the driver cd of the card. For setting up a PCI card simply insert it in the pci slot and install drivers when it asks you.
I think your PCI card needs drivers
Oct 02, 2007 | Keyspan SX Pro (SX-PRO4) Serial Adapter
Lenovo 46r1842 - Thinkcentre M57 Core 2 Duo System Board Wo Cpu Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
