Question about Zenith B25A10Z 25" TV
Horizontal lines across TV screen Panasonic CT-31SF13U
My picture is breaking down into horizontal lines. About midway in the screen there is kind of a horizon line. The lines are wider above it; tighter below it. This happened suddenly. The set was manufactured in September of 1996. Can I fix this or try some adjustment? If not, what might the repair costs be? Is it worth it or is my TV saying goodbye? Your advice is greatly appreciated.
Thank you,
Elodia
  • wayne chamberlain May 11, 2010
    This is a vertical deflection problem. usually there is one or more bad capacitors in the vertical circuit or a failing vertical output IC.
    If you post your model number i will be able to give a clearer response.
    Usually this repair would be $50 - $60
  • 89 Answers
The problem sounds like a vertical deflection issue form what you describe.
On average they are usually in the simple repair categories. On average they would run in the $50 range if you take it to a reputable repair shop.
There are several possibilities
Bad capacitor (s)
Bad vertical IC
resistor in the power supply to the vertical circuit changing value
Posted on Mar 13, 2009
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
No sound no picture high pitch sound
LOT [Line Output Transformer] fault. Check the horizontal scan output transistor too. If it is damaged, this kind of fault can occur. Anyway, the fault is related to its horizontal scan output section circuit. Check it. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Panasonic CT-36D31 36" TV
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
Jun 18, 2010 | Panasonic CT-36D11 36" TV
TV TURNS ON WITH NO PICTURE BUT YOU CAN HERE
you need some caps changed in that set in vertical circuit
i usually change about 5 caps to cure the problem
caps go bad over time
Dec 27, 2008 | Panasonic CT-32G11 32" TV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Zenith B25A10Z 25" TV Logo
1,033 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
