Question about Kodak EASYSHARE G610 Thermal Printer
Can't remove used ink cartridge from G600 Printer dock???
We need to replace used cartridge -but it it lodged tightlty in printer dock. there are no instructions how ro remove and replace this item??Please advise and or forward instructions. Thanks.
Carolyn
cbaccaire@cox.net
  • lisalandry12 Feb 13, 2009
    i have the same problem tried everything wont come out
  • Anonymous Mar 24, 2014
    if can be stored can you use existing equipment
Hold the transfer button down then hold the left arrow. Make sure the printer is on. Should here some clicking noise. When it completes then remove the ink cartridge.
Posted on Feb 13, 2009
  • debbie_ri784 Nov 12, 2010
    i actually had the same problem and did try holding the transfer button and left arrow key down and it did the noise but the ink cartridage did not budge so this is what worked for me i picked the printer dock up and hit it down on the desk once and it dislodged the printer ink and it was out of ink so that was the problem hope this works for you
How Do I load ink into a Kodak Easyshare G610 printer dock?
Posted on Mar 06, 2009
Ink cartridge stuck printer
The manual says: To remove the cartridge, push up on the Cartridge-release tab then pull out the cartridge. It looks like a green lever to me, you have to push.
Nov 27, 2013 | Kodak Easyshare G600 (1633379) Dock /...
I need to clean the printer cartridge jets. How do I do this
Hello thanks for using Fixya
In
HP PSC 1210 All-In-One InkJet Printer cleaning the cartridge is not difficult, but it is important to use the appropriate technique. The things you need is "Cotton swabs" & "Distilled water"
Now follow this procedure
  • Open the front door of the printer, located below the scanner lid, by swinging it down. The print cartridges will move to a position where they can be accessed
  • Unplug the printer to prevent the cartridge dock from moving away from the center of the printer. Press an ink cartridge down until you feel a "click" then pull it out of the dock.
  • Dip a cotton swab in distilled water and use it to clean any built-up ink from the metal contacts on the ink cartridge and from the area around the ink nozzle. Avoid touching the nozzle itself, which is located in the center of the bottom of the cartridge. Discard the cotton swab if it becomes dirty, and use another to continue cleaning. Keep cleaning until the ink cartridge is no longer dirty, then set the ink cartridge aside.
  • Remove the second ink cartridge and repeat the cleaning process. Set both cartridges aside until they are completely dry
  • Replace an ink cartridge by holding it slightly below the dock, then pushing it up and in until it snaps into place. Do the same with the second cartridge. The black cartridge is inserted into the right slot on the dock, while the color cartridge is inserted into the left slot.
  • Close the front door of the printer, plug the printer back in, and turn it on.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 26, 2011 | HP PSC 1210 All-In-One InkJet Printer
Printer isn't working correctly
To resolve this condition:
  1. Remove the power cable from the printer.
  2. Remove the paper tray from the printer.
  3. Remove the paper from the paper tray.
  4. Verify that the paper you're using has KODAK XTRALIFE Paper or a "G" inside a circle (for G600 series printer docks) on the back. Do not use 4- by 6-inch inkjet paper.
  5. Insert the paper tray into the printer.
  6. Open the color cartridge door, then remove the color cartridge.
  7. If the color cartridge ribbon is torn or damaged, replace it with a new cartridge.
  8. Install the color cartridge, and verify that it is fully engaged.
  9. Close the color cartridge door.
  10. Connect the power cable to the printer.
  11. Wait for the printer to initialize (the paper may eject automatically).
The printer's lights turn on. And after a few seconds, most or all of the printer's lights turn off. The printer will make noises while cycling. If a paper is stuck in the printer, while the printer is making the noises, pull gently on the paper to try and remove it.
If the problem persists, call 18002356325 to send camera for repair
Oct 28, 2009 | Cameras
G600 printer dock used about 6 months ago. Only
Yes, maybe the ink dry out. Try a deep cleaning several times, from the printer options.
If you don't use the printer, you should weekly print a test page to avoid this problem.
Aug 27, 2009 | Kodak Easyshare Printer G600 Thermo...
Kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
May 27, 2009 | Kodak Easyshare Printer G600 Thermo...
Ink cartridge is empty and I can not remove it to change it. It won't come out!
Press the power button to turn off the printer. Hold down the transfer and left arrow button at the same time. While holding them down at the same time turn on the power button. Let it go through the initialization process and once completed, the head should be in the up position. Open the cartridge door and push the cartridge to make sure it is latched and locked in place. Once the cartridge is latched, release the latch and the cartridge should release itself. Remove the cartridge from the printer.
May 18, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Kodak printer dock cartridge is stuck inside printer dock
turn off your printer. Press and hold down the left arrow and the transfer button, turn on printer while holding them down, you should hear your printer make some noises, This will be the head lining up. Open the side door to gain access to the cartridge, push on it to see that it i s"locked" in. Lift up on the Green release button on the inside and your cartridge should come free on its own. Be careful not to try and pry it out for this can void your warranty! http://www.wonderhowto.com/how-to/video/how-to-remove-a-stuck-cartridge-on-a-kodak-g600-printer-dock-249276/view/
May 15, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
I found a how to video on the web.Turn off your printer. Hold down the left arrow button and transfer button at the same time, then turn your printer back on. You should hear it make some noises, open side door push on cartridge to see that it is locked in. Then hit the green release button on the inside and the cartridge should come out on its own.
Mar 20, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Kodak Easyshare G600 printer dock problem!
I HAD THE SAME PROBLEM. tALKED WITH THE KODAK TECH LINE AND THEY TOLD ME TO...TURN OFF PRINTER, HOLD TRANSFER BUTTON AND LEFT ARROW DOWN AT THE SAME TIME AND TURN THE PRINTER ON. DO THIS THREE TIMES. iT WORKED FOR ME. GIVE IT A TRY.
Jul 31, 2008 | Kodak Easyshare Printer G600 Thermo...
Kodak EASYSHARE G610 Thermal Printer Logo
377 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
