Question about Kenmore Microwave Ovens
The bell sound on the microwave quit--otherwise unit works find
The unit is 6 years old and is a built in Kenmore Elite. When the bell quit the time also went off but I was able to reset that.
  • Kenmore Master
  • 9,085 Answers
Try a hard reset by unplugging the oven for a minute or so, then plugging it back in, setting the clock, and checking it again.
If it still doesn't sound, check your owner's manual to see it the sound can be controlled via the control panel.
If for some reason you don't still have yours, you can find it here.
Posted on Jan 17, 2013
Testimonial: "Thank you for the imput. My microwave is a built in so will enlist some help as it is upper cupboard high and the plug in is behind it. Gosh--doesn't anything last anymore? "
SOURCE: Microwave does not heat
Just had the same experience with the identical model. Removed the cover (a challenge because of the security screws), revealing valuable troubleshooting directions intended for an experienced technician. However, I think the info is well within the reach of a typical DIY person, does not require any dangerous power-on conditions. However, make sure that you discharge the HV capacitor before trouble shooting. In my case, it appears that the HV diode is open, have ordered a replacement on the internet for $3.18, easy to replace. Hope it works. Good luck.
Posted on Jul 14, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Turn off Beep on old Magic Chef microwave
On some older models, there is a sliding switch on the bottom edge of the control panel that turns it off. I've seen these on older Amanas, but not sure about others.
In newer models, they have some kind of help key which will get to to a menu which will turn it off.
Other models in between usually don't have that feature. In such cases, I as a technician have removed the beeper or taped over it to make it quieter, or even lifted one leg of a resistor attached to the beeper.
Someone less technical or less patient could just push the beeper sideways until it snaps off. No more beeps! *grin* And really, it is much weaker than the circuit board so it's a viable, if inelegant solution.
One other thing is to call Magic Chef with your model number:
http://www.mcappliance.com/contactus/contactus.asp
Posted on Nov 18, 2007
Skill Will
  • 53 Answers
SOURCE: Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Posted on Mar 23, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: kenmore microwave 721.80412500
The owner's manual should spell that all out.
But if you don't still have yours, you can download one via Sears' "Manage My Home" site here. While it's free, you will have to register.
(You *may* be able to download it here without logging in. If not, go ahead and register. It's free.)
Posted on Sep 25, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Posted on Dec 02, 2008
Not realy...Kenmore Elite microwave runs 3 seconds then stops. All other functions work ok. Model 790.80363310
Not familiar with That Kenmore elite model. But with the symptoms I would bet your unit may have an inverter, which is the power source for the part that puts out the microwave energy the Magnetron to run, If that is the case it could be a bad inverter AND a bad magnetron. If the unit isn't anything really special to you I would recommend replacing it as the repair will be quite expensive
Nov 01, 2017 | Microwave Ovens
My Kenmore elite built in microwave oven model 790 488 03100 has stoppped heating what can i do
It may be a bad fuse or capicitor. I have had a time in the past with something similar. I contacted Repair Clinic.com. They were very helpful with their advice and even followed up to make sure I got things fixed okay.
Dec 09, 2014 | Kenmore Microwave Ovens
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Kenmore elite microwave troubleshooting
My GE microwave buzzes at times but otherwise works just fine.
Jan 20, 2014 | Microwave Ovens
Kenmore elite countertop microwave/convection oven
Time for a new cover plate or a new microwave. Depending on the age of the unit, the part may not be available anymore.
Jul 06, 2017 | Kenmore Microwave Ovens
My kenmore elite microwave is loosing power
I'm afraid the magnetron (most expensive part - generates the microwaves) is on its way out. In most cases, it doesn't pay to repair it - unless the replacement would cost over $200 and/or hard to find the right size for built-in. I would vote for replace with new - you've had a good run for the money, but this might not be the only problem that develops soon. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Jun 26, 2009 | Microwave Ovens
Troubleshooting my Kenmore 721.66227
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Otherwise, when you hit Start to cook, do the inside light and turntable come on?
Any unusual noises?
Is it louder or quieter than usual?
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting Sears to get it fixed free.
Aug 21, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Microwave Ovens Logo
180 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
