Question about D-Link DIR-615 Wireless Router
How do I connect d-link from current computer to a new computer
My current computer does not work well. I currently use the d-link flash drive. I have another computer and would like to use the d-link flash drive on the new computer. What do I need to do?
  • D-Link Master
  • 32,281 Answers
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Posted on Jan 17, 2013
3 Suggested Answers
heavyice
  • 374 Answers
SOURCE: Unable to connect D-Link Hub to internet via
Connect the modem directly to the Computer first and try n go online.If everything works fine then this is the no. for the
D-Link Tech Support 1-877-453-5465
It's a toll free number call them and they will guide you step by step in a proper way.
If you are not able to go online with the modem directly connected to the PC then call the hughesnet customer care 866-347-3292.
Good luck.
Posted on Mar 15, 2010
  • 1768 Answers
SOURCE: My computer (Windows XP installed) has working
change the setting in the router to accept any connection.
you will have to log into the router to do this.
Posted on Oct 11, 2010
Tip
How to Download Files to USB Flash Drive
MS Windows Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. <br />Depending on your computer, there can be USB ports on the back, side or front. The flash drive can also be connected to an external port hub device. Once you connect it, the computer will automatically recognize it as a removal device.<br /> 2.Double-click "My Computer" on the desktop. You should see your USB flash drive's icon listed together with other removal devices on your computer.<br /> 3.Double-click the flash drive's icon to open the flash drive window and <br />reveal the contents saved on it. Locate the file you want to download to the <br />flash drive from its current location on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive.<br /> 5.Close the flash drive when you are done. Click the "Safely Remove Hardware" icon on the system tray. A new window will open. Left-click the flash drive and click "Stop." A message will pop-up indicating that it is safe to remove the device from the computer. Disconnect the USB flash drive from the computer (or external hub).<br /> <br />Mac Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. The computer will automatically recognize the device and display its icon on the desktop.<br /> 2.Double-click the flash drive icon on the desktop to open its window and <br />reveal the contents on it.<br /> 3.Locate the file you want to download to the flash drive from the location <br />where you have it saved on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive. Close the flash drive window when you are done and drag the flash drive icon to the trash can to safely eject it from the computer.
on Feb 01, 2011 | Computers & Internet
How do I add more memory to my dell dimension 3000 computer thatn has a 34 GB Harddrive?
Go buy an IDE hard drive of whichever size you want, and connect it to the IDE cable that your current drive is connected to inside the computer. If you don't want to reinstall windows, you'll have to either purchase a separate IDE cable and connect the new drive to another IDE port on your motherboard (IDE cables are the thin, flattned cables that are fairly wide) If your current IDE cable has a freed up connection, ensure that your drives are jumpered properly with the master/slave options that should be printed on the drive itself, with a diagram. Your main drive (34GB) should be the master, the new one set to slave - this will keep the computer booting off of your current hard drive. It may seem intimidating, but installing a new hard drive is easy once you open up the computer and start comparing parts, looking for your hard drive ports and power supply cables. Just make sure the IDE cable and the power supply cable are firmly attached to the new hard drive when you install it.(power supply cable usually has a white tip, with four loosely bound wires leading to it) I hope this helps!
Nov 18, 2010 | Dell Dimension 3000 PC Desktop
I am currently on a school computer. My SanDisk Cruzer 8gb would not run. I recently added a password on it and it has worked before. The U3 system would not auto-run and I have tried running it manually...
> currently on a school policy.
The school's Computer Systems Administrator may have installed a "Group Policy" setting that tells Windows to *NOT* allow USB-devices (iPod, iPad, flash-drives, external disk-drives) to be allowed to be used. It's a good way of preventing computer-viruses from getting onto the school's computers.
If your SanDisk works correctly on your own computer, then use your own computer.
Nov 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My book essential edition - 500Gb. Model no. WD5000H1U-00 It would appear that the power supply adaptor is not working since there is no power when plugged in. It is still in warranty, any advice on how...
> it is still in warranty
If you exercise the warranty, you'll have to send the current device back to W.D.
But, W.D. will take _no_ responsibility for 'rescuing' the files currently on the disk.
Is that what you want?
Disassemble the enclosure, and remove the disk-drive.
Connect it as a 'slave' disk-drive in a desktop computer.
If it works, the disk-drive is OK.
So, look at: http://www.canadaram.com/3_5_sata_enclosures.htm
and buy a new enclosure, with a new power-supply.
(Or, buy the new enclosure locally, at any computer-store.)
Disassemble your current unit, remove the disk-drive,
and transplant the disk-drive into the new enclosure.
Oct 05, 2010 | Western Digital My Book Essential Edition...
How to flash my dcm425 cable modem
Ive never heard of flashing a modem before. A router you can.
Who is your ISP provider? They can get you a new modem.
Sep 04, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Computer is not recognising the flash drive
Do other computers read the flash drive? If not, faulty drive. If yes, it may be recognized but you have Auto-play disabled. That's actually a good thing. Assuming this is a Windows computer that is at least XP or newer, open Windows Explorer (not Internet Explorer) BEFORE connecting the USB drive. Then left-click on the My Computer item. The right side of the screen will display all currently recognized drives. Plug in the USB drive and watch the righ side of the screen. I'll bet a new drive will appear within about 45 seconds. If so, just double click on the new drive and you'll see all your "stuff". If not, you may have a faulty USB port.
Aug 28, 2008 | Computers & Internet
Error code 10
wow i think i solved it by just giving your mom the Alabama Hot Pocket while i licked your sister. that seemed to work pretty well.
Nov 03, 2006 | LaCie d2 Extreme 250GB External with...
D-Link DIR-615 Wireless Router Logo
41 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
