Question about Amana ACD2232HR Side by Side Refrigerator
Water build up in the freezer
I have a kenmore refrigerator with top freezer. there is always water building up in the freezer (back and roof), and then dripping down.
in summer the freezer gets not cold enough
the question is whether it is worth repairing it, or should i just buy a new one...
    President:
  • Amana Master
  • 2,651 Answers
Sorry about the delay in responding, saw an open call, hope this is helpfull too you !!!
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Mar 02, 2009
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
I had water in bottom of kenmore fridge. This is now fixed but soon after I had frost building up on back wall of freezer.
you now have a defrost issue,remove rear panel inside freezer if the evaporator is covered with a heavy ice and frost build-up then either the defrost heater under the evaporator coil is open or the defrost thermostat on top of the coil is bad you need to check both for continuity or the defrost timer if equipped or the A.D.C. adaptive defrost control is bad and not supplying power to the defrost circuit
May 02, 2012 | Kenmore Top Freezer Refrigerator
Water leaking in the regrigerator and falling /frost build up
the door may be sagging or the door gasket could be torn or loose from the door. whats happening is the moisturew in the air is forming ice build up. check and make sure the door and gasket are completely closed.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
When your refrigerator defrost the condensation has no place to exit to because of a restriction in the drain and that could be water that has turned into ice or possiably a food partical or foreign object. Defrost it compleatly by leaving freezer door open for aprox. an hour at least make sure ref is level front to back an d you should not have this problem anymore. Please rate me and let me know if this helped. Thanks
May 22, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Leak in fridge from between fridge roof and freezer, fridge is still cold as is freezer however will not stop leaking
Hi, The drain hole located in the freezer defrost drain is plugged. Get me your model # and I can assist you further.
THanks
Vic
May 17, 2009 | Refrigerators
Kenmore # 63142 Fridge -- Water in Freezer
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
Apr 04, 2009 | Kenmore 63142 / 63144 Top Freezer...
Leaking water
Look at your door gaskets. If they ain't kosher then excessive humidity will build into the frig.
Jan 02, 2009 | Frigidaire GLRT188WD Top Freezer...
Water present in refrigerator compartment
probable cause is the defrost element in the bottom of the freezer compartment allowing ice to build probable need to replace defrost element
Oct 11, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Kenmore refrigerator
clogger drain,find it inside frig,freezer or on back on **** out with shop vac
Sep 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Amana ACD2232HR Side by Side Refrigerator Logo
79 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
