Question about Dell Vostro Computers & Internet
Blank screen on Dell Vostro after "resuming windows" comes up
Only the cursor can be seen. It does take awhile to go off when I shut it down so I am assuming that I just can't see what is actually on the screen.
    New Friend:
  • 20 Answers
Have you tried updating the Graphics drivers? Some driver issues have been reported with Windows Vista and 7 coming out of resume and most are fixed by updating to the latest drivers?
Posted on Jan 16, 2013
  • 86 Answers
SOURCE: Screen goes blank at start up
Its failing to go through the full boot process. Try pressing F8 on boot until the boot option screen comes up and then select safe mode. Follow this though until you are given the option of using system restore instead of safe mode. take that option by clicking on the NO button. Restore the machine to a date some time a few days previous to the fault developing.
If that fails then put in any OS disc and boot from it. select R at the first options screen, follow it through and then select the C drive option. Just hit enter when asked for admin password.
now type chkdsk /r (copy and paste this to be sure). let it run and then reboot and see what happens
Posted on Dec 15, 2008
  • 1019 Answers
SOURCE: Dell D610 Latop screen wont resume after it has been shut
it is possible that the latch is sticking. located under the lid.
try pressing the small button, with a small blunt screwdriver.
Failing this, adjust the settings in My Computer/Control Panel/Display settings or Similar. If they,re adjusted to hibernate/sleep/shut-down computer, when i close the lid.
this is where the problem will be. Try changing to Do-Nothing or similar.
Thankyou For Using Fixya.
Mike @ compurepair.
Posted on Jan 09, 2009
heavymetal77
  • 721 Answers
SOURCE: I have Dell Vostro 1000 which won't boot up. Can
Sounds like the hard drive went bad.
Posted on Jul 14, 2009
  • 247 Answers
SOURCE: Turn on my Dell Vostro 1500 and all I get is a black screen
Remove and re-seat your RAM cards. Remove your battery but leave the power supply attached. Try to start. If this doesn't work, your motherboard has died and needs to be replaced. Not a do-it-yourself job unfortunately.
Posted on Sep 07, 2009
  • 113 Answers
SOURCE: Dell Vostro 1700 will not shut down
try to press and hold power button for 5-10seconds if it still turns on by itself need to repalce the hinge cover of computer
Posted on Feb 26, 2010
Vostro 1500 screen blank except for flashing cursor
The good news is that your laptop powers on and you have a display. The bad news is that you laptop is trying to boot up from an OS (operating system software) like XP, Vista, or Win 7. Ether your software is corrupted or you have a problem with the hard drive or hard drive controller.
Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Another more intense diagnostic program is located on a Dell CD that you should have received with your laptop. Look for one that has "Diagnostics and utilities" listed under the "Contents". You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the "One time boot menu". Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the "Run the 32 Bit Dell Diagnostics".
If diagnostics pass then your software is corrupted and needs to be reinstalled.
Mar 03, 2013 | Dell Vostro 1500 Notebook
Screen goes blank after windows corporation logo
perhaps you need to reinstall the operating system,the system files might be corrupted because of power problem,and there's "windows loading files" thing,so the windows cannot go further because it cannot find some files while loading. do you need any help with installing operating system?
Aug 25, 2012 | Toshiba Satellite Pro L300 Notebook
Dell Vostro 200 goes straight to analog mode/sleep, keyboard, mouse not responding; not booting
replace bios battery, reset the bios, insert required parameters after rebooting and when windows reboot change the time period for screen saver and hard disk shut down!
Aug 05, 2012 | Dell Vostro 200 PC Desktop
I m unable to install xp on dell vostro 1015 with 2 gb ram and intel core 2 duo cpu (t6570) ( the laptop came with preinstalled windows 7 and i have also successfully installed red hat linux 5 server...
If you try to run XP setup without changing the BIOS SATA setting to ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
Oct 12, 2010 | Dell Vostro 1015 Laptop
The laptop loads up, lets me sign in, then goes blank, no icons
Try booting to the safe mode (F8 at boot) and see if you can log in via the safe mode. If you can't, try booting to your Windows CD, go to recovery console and run CHKDSK /R
If you still can't log in, try running diags see if the hard drive lists a failure.
if no hardware failure found, there and none of those solutions work, then re-installing windows will likely be the final resolution
Oct 06, 2009 | Dell Vostro 1500 Notebook
Vostro 1500 does not boot
hi
dear it is not note book problem it is windows problem
insert boot cd of your desire windows repair it
thanks
Jul 19, 2009 | Dell Vostro 1500 Notebook
Computers & Internet Logo
53 people viewed this question
Alun Cox
