Question about Craftsman Lawn Tractor Operators Manual 536.270300
Need a replacement spark plug
Replacement for rj4c plug
I have a broken spark plug wire. Can these be replaced?
Steve:
Yes, the spark plug wire can be replaced, but you have to buy the ignition coil as the spark plug wire is hard wired into the ignition coil.
If the metal spark plug connector has disconnected from the spark plug wire, the connector can be replaced, but if the spark plug wire has been cut you'll need to replace the ignition coil.
Nov 29, 2013 | Homelite 200 mph 400 CFM Gas Blower...
Steps to change a spark plug
easy job replace one spark plug at a time.you need buy new set of spark plug wires and spark plugs.reason need new wires possible old ones will break from inside plug boot when you remove plug wires.you need basic 3/8 ratchet wrench.you need long short extensions.need spark plug socket.need spark plug gap gauge.need a universal joint connect to the extensions to reach sharp angles.make sure engine cold when replacing spark plugs could damage heads.use a 12 inch piece vacuum hose to help aid in installing sparks in hard reach spaces with out damaging crosss threading plugs threads and cylinder head threads to plug.
Apr 25, 2013 | 1998 Pontiac Grand Prix
Replace spark plug's
Things you will need
Spark Plug Socket And Wrench of the correct size for your spark plugs
Basic Instructions.
Step 1
Locate your spark plugs
look for other obstructions besides your spark plug wires
if you have any other obstructions you will need to remove them as well to gain access to your spark plugs.
Step 2
Remove the spark plug wire for one single spark plug at a time.
this will insure you will not replace the wrond spark plug wire to the incorrect spark plug,
if not done this way you could change the firing order of your engine.
Step 3
With your spark plug Socket and wrench rotate the spark plug in a counter clock wise direction for removing.
Step 4
After you have removed your spark plug insert your new replacement spark Plug into your spark plug socket before inserting it into the correct location. spark plug sockets are made to hold on to the spark plug for easy removal and install.
Step 5
insert your new spark plug,
before you rotate your spark plug for tightening rotate the spark plug a 1 quarter turn in the counter clock wise direction, then start tightening the spark plug by rotating it in a clockwise direction
This will insure you will not strip the threads.
Step 6
Continue rotation your spark plug in the clock wise direction untill snug, then with just a lil more pressure tighten it up just a little more.
be sure to not put to much force on the spark plug after it has been snug, you just have to apply a little more pressure but not to much that could cause it to break.
Step 7
After tightening the spark plug replace the correct spark plug wire.
then move on to the next spark plug and follow the same instructions.
if you have any other visiable obstructions preventing you access for replacing your spark plugs you will need instructions on how to remove them parts. i have just instructed you on how to remove and reinstall the spark plugs only.
Feb 16, 2013 | 2008 Mazda Tribute
Need to replace sparkplugs on 2002 ford escape
well replace spark plugs is not a hard job,when replacing spark plugs, good time to replace plug wires also.you need to replace one spark plug at a time so you wont mix up firing order. you need a spark socket, torque wrench, 3/8 ratchet wrench, 3/8 short and long extensions,you need a spark plug gap gauge.spark plug gap for 2.0 engine 0.051 the 3.0 engine spark plug gap is 0.052 - 0.056. just follow spark plug wires they will lead you to the spark plugs.warning wait until engine cool down first because removing spark plugs from hot engine could damaged the aluminum heads,use compressed to blow away debris before removing spark plugs keep debris falling into the cylinders.wear safety glasses if you use compress air and use small amount anti seize compound to the spark plug threads.good idea slip a short length rubber hose over the end of spark plug to use as a tool thread it into place.reason i use piece vacuum hose it will grip the spark plug enough to turn it, but will start to slip if the plug begin to cross thread.when installing spark plug, it should turn at least few times if spark plug start tighten before 1/4 turn thread cross threading need to back off start over dont keep turning you will stripped spark plugs threads in the head also damage spark plug threads, so be careful, good luck with job.
Aug 26, 2012 | 2002 Ford Escape
Is a special tool required to change spark plugs in the 3.2L engine?
you will need 5/8 spark plug socket as well as a long extension to replace spark plugs.That you can get at local auto part stores.Plugs are on either rocker cover....there are 3 ign coils on each rocker cover that need to be removed then remove the plugs You will need a 5/8 spark plug socket as well as a long extension to replace them 8mm socket holds the individual coils on.
------------ ON 3.2L there are acually no spark plug wires, the engine acually has whats called, coil over plug which means the the power to make a spark plug spark, happens right over your spark plug. Now in order to get to the spark plugs which are under the coils you have to first unscrew the screws, there'll be two phillips head screws per coil, after that just pull the coil out, it should be about 3 inches, the spark plugs are at the bottom of the hole that you just uncoverd, you'll need an extesion for your socket in order to reach them, take them out, replace, put the coil back on top making sure that its seated ontop of the spark plug, put the two screws back in, tighten and your done with one, continue for all.
---------------- this should help.thanks.Helpmech.
Mar 01, 2011 | 1997 Isuzu Rodeo
Cylender number 1 misfire,
Do a complete tune up.. Spark plugs, wires, distributor cap, and rotor button... If it has coil packs that sit on top of the spark plugs.. Replace the spark plugs and cylinder number one coil
Feb 15, 2011 | 1998 Nissan 200SX
Do i need to replace spark plugs at 60,000 miles on my 2007 eclipse?
IF YOU HAVE STANDARD SPARK PLUGS REPLACE THEM AT 30000 MILES. IF YOU HAVE IRIDIUM SPARK PLUGS REPLACE THEM AT 105000 MILES. IF YOU HAVE PLATINUM SPARK PLUGS REPLACE THEM AT 60000 MILES.
Nov 22, 2010 | 2007 Mitsubishi Eclipse
Remove and replace spark plugs
not to bad you'll need long extension, front one are there in view, the back one's remove spark plug boot (long one) and with extension you can reach spark plug's.
Dec 11, 2009 | 2000 Mazda MPV
Craftsman Lawn Tractor Operators Manual 536.270300 Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
