Question about D-Link DIR-615 Wireless Router
How do i connect d-link to new computer
I currently use the secondary flash drive. my computer no longer functions well and I would like to hook up current flash drive to another computer.
  • 7,627 Answers
3 Suggested Answers
SOURCE: Connecting DLink thru Comcast Cable Modem and Vonage box
i have comcast wifi and i cannot set up vp eye to eye. i try to make phone call and get message says the phone number i call is unregistered. pls help me! thanks. my email is deafjrt@aol.com
Posted on Sep 17, 2008
heavyice
  • 374 Answers
SOURCE: Unable to connect D-Link Hub to internet via
Connect the modem directly to the Computer first and try n go online.If everything works fine then this is the no. for the
D-Link Tech Support 1-877-453-5465
It's a toll free number call them and they will guide you step by step in a proper way.
If you are not able to go online with the modem directly connected to the PC then call the hughesnet customer care 866-347-3292.
Good luck.
Posted on Mar 15, 2010
I used this with an old computer. Can I use it for my current computer? Do I need to wipe it? If so, how?
Plug it into a working computer as a secondary hard drive and working off the main drive simply give the command to format the secondary drive.
Aug 09, 2015 | Computers & Internet
How do I connect d-link from current computer to a new computer
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Jan 16, 2013 | D-Link DIR-615 Wireless Router
Old computer with windows xp won't boot - how can I get the data off the hard drive by hooking it up to my new computer with windows vista?
You should be able to put the old hard drive in the new computer and connect it as a secondary drive. That all depends on the type of interface the new computer is using. Most new computers use SATA inferface for HDD now. You're old drive might be IDE. in which case you can't add it to new computer unless it also has IDE interface on new MB. If no IDE interface on new MB, you can use USB 2.0 to IDE or Serial ATA Drive Adapter Cable from Cablestogo.com to connect your old drive via USB.
Apr 01, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
I have a Fanner SPIRE Aluminium Gigapod External 3.5" external hard drive linked to my Windows XP laptop but the link up between the two has recently become increasingly slower as has the response of the...
The hard disk inside that Spire case has died - running the free space clean from CCleaner (a very intensive procedure) has been the death blow to an already sick disk.. Nothing more can be done to save it and the data on it. Replace it with a new one.
Jul 17, 2010 | Fanner SPIRE Aluminium GigaPod External...
I have 2 laptops hooked up to one monitor when i hit the switch the one computer works with the monitor when i hit the switch to go to the other computer the secondary monitor no longer works ive tried...
i have found that some graphics cards only allow for one monitor. at least that is how it was when i had an acer a few years ago, i currently have an area 51 m9750 which has a much better graphics card setup so it has the option for multiple external monitors...
May 20, 2010 | Belkin F1DF102PEA 2-port KVM Switch
Ide channels not working right after updating dvdrw firmware Set on ide channels should be Primary ide Hard drive primary master. Primary secondary hard drive. Secondary master dvd (read only) Secondary...
usually when you update or re-flash the dvd rom.
it will state :- ensure that the drive to be flashed should be jumper set as master. if there were other drives connected to the same ide channel. this could have caused damage to the other drives connected. Or the IDE Channels themselves.
The only suggestion I have for you. is to remove all the drives. disconnect the power from the computer. and remove the cmos battery, for 10-15 seconds. resetting the computers bios back to defaults. then re-settup the drives ensuring that the jumpers are correct for each drive. i.e 1 slave and 1 master on each ide cable.
Mike @ Compurepair.
Mar 26, 2009 | ASUS A7V8X Motherboard
Dell2 2400 BIOS F2 reads backwords.
It sounds like you may have the IDE cables hooked up backwards on your motherboard.. The IDE cable slot on the motherboard labled IDE1 should be where your Hard drives are if you want them to read as primary. The Optical drives are usually on IDE2, designating them as secondary.
Let me know if you need more help.
Mar 12, 2009 | Dell Dimension 2400 PC Desktop
How to flash my dcm425 cable modem
Ive never heard of flashing a modem before. A router you can.
Who is your ISP provider? They can get you a new modem.
Sep 04, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How do i remove the hardrive from my packard bell club 79 computer?I have some pics on there i would like to put on my new pc,my old packard club 79 will no longer connect to the net though(so i cant...
the harddrive is likely to be located with some screws
Remove these screws
There will be a ribbon cable and a power lead - remove these
you will then need to install this into your current PC.
1 - Do you have a spare line or space on an IDE line...
2 - You will need to establish whether you are on primary or secondary line, and then if you need to set your hard drive to be a master or slave Hard drive (recommned slave on the 'other' line to your master hard drive) - this will improve the communication speed.
Aug 17, 2008 | Packard Bell Computers & Internet
How to recover data from a seemingly dead/non-functional USB flash drive
I own three flash drives, and follow this procedure. When you connect a flash drive, it should show up in "My Computer" as a removable drive - with a letter designation. Windows 98 requires driver software, XP and VISTA does NOT.
When you DISCONNECT the flash drive, you should "right click" on the drive icon, and select EJECT. The little light on the flash drive will go OUT, and THEN IT IS SAFE TO REMOVE IT. If you just pull the flash drive out without going through the disconnect ritual, you risk blowing the drive, and it is kaput. Doesn't always happen, but it can.
May 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
D-Link DIR-615 Wireless Router Logo
62 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
