Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
I have a Dyson DC07 when you un attach cylinder for emptying all what i have hoovered falls out on the floor what do i need to buy to fix it
  • Dyson Master
  • 18,391 Answers
It may need a new bin flap
Posted on Jan 18, 2013
  • 72 Answers
SOURCE: Emptying cylinder
I hope you've found out by now, but, in case you haven't, the latch to remove the canister is right by the handle on top of it, just don't lift until you release the latch with your thumb, it's got a safety to keep you from hitting the release when you're using that handle to carry the vacuum.  (good engineering).
you can download a manual from the dyson site, here:
http://www.dyson.com/customercare/manuals/us/dc07_opmanual_usa.pdf
Posted on Oct 20, 2007
SOURCE: Dyson DC07 burning smell.
sounds like it is on the way out this may be because 1, you need to clean the filter cos when its dirty it stop air from going around the motor witch makes it get hot and overheat 2, also if you allow the bin to get to full this will also stop the motor from geting air to it so a good clean on your filter and bin will allow air to the motor then no overheating should accur
Posted on Jun 17, 2007
SOURCE: Dyson Dc07
I had the same issue and solved it easily.My experience is the same as the March 6th response/ When you push your foot onto the base and then recline the handle, use your toe to gently push the very front of the base down closer to the carpet. This creates a much stronger seal and suction and picks up every bit of dirt easily. If i do not do this extra step the suction is much much less. I tried an experiment with sand that I poured onto my carpet. Initially, I went over the sand 4 times and the dyson 07 would only pick up 50 percent of the sand. I then poured more sand onto the carpet, and this time pushed the front lip down so it was contacting the carpet. This time only two passes were needed to completely **** up all the sand. Not sure why this is not in the manual but it really works. Good Luck!
Posted on Jun 29, 2008
  • 5 Answers
SOURCE: dyson dc07 yellow/blue no suction at base
Sounds like you've **** up something which is obstructing the suction from the brush bar. There's a little section of curved grey pipe near the base which carries the dirt from the head up the vertical pipe at the back. This section can be removed, check there is nothing jammed in there, paper etc.
Posted on Aug 12, 2009
VacuumRepair
  • 438 Answers
SOURCE: dyson dc07 animal\ no suction
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
Posted on Apr 04, 2010
Dyson DC07 leaves large dust marks on floor while upright
Hi Tracy, it's Jack at Dyson.
If dust is coming back out of your DC07's cleaner head, this suggests that the machine may have a blockage. It's also worth checking that the internal hose isn't damaged, and removing any threads or hair from around the brush bar.
The easiest way to check for and clear any blockages is to follow the steps shown in our online support guide: http://www.dyson.co.uk/support/dc07/dc07-standard/my-machine-is-not-working/my-machine-is-dropping-debris-from-the-base/loss-of-performance
If you haven't washed both parts of the pre-filter recently, it's also a good idea to do this. In normal use this should be done at least once every 3-6 months using cold water without detergent. Make sure both parts of the filter are completely dry before replacing them - this may take at least 12 hours.
This should resolve things, but if you have any further issues after giving these steps a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so our experts can provide further assistance.
Dec 09, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
I have a Dyson DC07 upright vacuum I emptied the cylinder and the bottom lid fell off not sure how to reattach in case it breaks - any clues?
It has two little pegs that hold it onto the perspex cylinder. Really, it shouldn't fall off during normal use. Check one of the little pegs hasn't broken off. If it has, you need to replace the bin flap. If the pegs are OK, check the two mounting holes on the perspex cylinder. If you need to replace either, you can get them from here: http://manchestervacs.co.uk/Dyson/DC07-spares.html as Dyson will not sell you cylinder components but those guys will.
Jan 14, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have the dyson dc07 all floors and have a new belt- I have removed the black cover but cannot see where to attach the new belt ! Hope you can help-Carole
Hi there Carole, VacuumGuru here.
I have made a video on how to access the brush roller and clutch for a dyson DC07 vacuum cleaner. It will be a really good place to start so you can see how it comes apart. If you have more queries after watching the video I am more than happy to help.
If you need to buy parts for your dyson vacuum cleaner try vacuumspot or nelsonvacuums (both online).
Hope this helps :)
Please take the time to leave a testimonial if you find this info useful.
Nov 14, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a dyson dc07 hoover, is it possible to replace the carry handle
Hi thanks for contacting FixYa. My name is Don.
Whilst it is "possible" to fix the carry handle it is a far trickier job than just buying a whole new Cyclone. For this reason Dyson do not sell the handle separately.
I would suggest you buy the whole new cyclone. You can buy them new for around £30 £40 from Dyson or Espares.co.uk.
You could probably get a second hand one or better still a refurbished one on eBay though. Shouldnt cost you too much on Ebay. Maybe £15
Hope this answers your query.
Thanks for contacting FixYa. Don
Oct 24, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Cleaner head not pivoting freely.
the spring might be disattachd because of the fall check inside the cleaner head if you can attach it thank you
May 28, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Ive got a sock in the tube
remove dust bin from hover and remove handle from hose then remove hose from hover and push a peice of doul up hose to remove sock and rebuild hover or buy new hose hope this helps
Nov 26, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Poor Suction
I recently bought a second hand Dyson DC07. Its suction was poor. I removed all the un-clipable pipe bits and to remove any blockage but it all looked clear. The Final Sponge and hepper filter did have a lot of dust in it and the rotating brush was full of hair but nothing bad.
I eventual gave in to curiosity and removed the three screws in the top or the yellow removable dust collection tube and cyclone bit to see what was in there. The mechanism to release the flap at the bottom of the collection tube does not allow you to remove the lid completely but it does open far enough to get inside. I found the whole top section of the yellow plastic bit blocked by a big plug of compacted dust and a champagne cork. If you are willing to take the risk and have a torx 15 screwdriver handy it that part may be blocked. It did get a bit messy.
If I was going to attempt the same procedure I'd remove the dust collection unit from the vacuum cleaner as I did before, but leave the clear tube attached and the emptying flap firmly closed to reduce the mess from the dust falling out the bottom while cleaning the top part.
Oct 23, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hose buckling/crumpling when hoover is turned on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=34170&thid=580414
Hose buckling/crumpling when Hoover is turned on
Posted by mildwarthog on May 08, 2008
Hi - I'm having a problem when I turn my Dyson DC07 on, that the suction is causing the hose to buckle/crumple out of shape which then means I can’t Hoover through the hose. After a short while the motor starts to overheat from trying to maintain suction through the crumpled hose is it simply time to buy a new hose, or is there anything else I can do to fix this problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Dyson DC07 All Floors Bagless Upright
Once you hose starts to breakdown there is really nothing you can do other than replacing the hose. This is true on almost every vacuum on the market because they are using in most case the plastic hose and the heat and the product you pickup breaks down the hose and starts to lose its strength and starts to collapse. You may want to check with your local vac dealer to see if he has a new one or a good used one for ½ the price. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.dyson.com/homepage.asp
Contact Us
1-866-MY-DYSON
(1-866-693-9766)
Dyson Customer Care is available 7 days a week.
· Mon - Fri: 7am - 8pm, CST
· Saturday: 8am - 6pm, CST
· Sunday: 9am - 6pm, CST
questions@dyson.com
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 08, 2008 | Dyson DC07 All Floors Bagless Upright...
Suction
Hi. The problem will lie with the cyclone being clogged up. If you are unsure how to fix this try this site. http://dysonmanuals.inc.io/
Sep 21, 2007 | Dyson DC07 All Floors Bagless Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
60 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
