Question about Garden
Stihl 023 runs OK but the chain does not turn
Revs OK, drive sprocket does not engage
    Sergeant:
  • 322 Answers
Since that is a centrifugal clutch, the speed of the engine is what turns the sprocket. If it revs good and doesn't turn then I would have to assume that the clutch is not making contact with the drum, the chain brake is on, or it really isn't revving the way you might think it should. If it is a clutch issue then it should over rev.
Posted on Jan 17, 2013
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
  • 61 Answers
SOURCE: homelite chainsaw sprocket and clutch for chain
You can get the parts at your local tool rental store.. They should be able to do the service themselves to if you dont want to do it.. Let me know how you make out..
Posted on Jul 10, 2009
dontbother10
  • 2220 Answers
SOURCE: i took the sprocket cover off to remove the bar
It must be reset before you can reinstall it.
This answer stolen from Dolfoff;
Clamp the cover in a vise being careful to stay on flat surfaces of the cover (use wooden blocks if needed) and pull the brake lever back to the "OFF" position. It's a strong spring so pull hard in the direction that would be towards the rear of the saw if the cover were installed.
Hope this helps.
GL
Lou
Posted on Oct 06, 2009
dontbother10
  • 2220 Answers
SOURCE: Echo chain saw sprocket not turning.
A few clicks form here will get an Illustrated Parts Manual, I find them them helpful.
EchoUSA
http://www.echo-usa.com/faqs.asp
If I read the pictures correctly it has an outboard clutch, this may also be helpful.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
Lou
Posted on Nov 11, 2009
dontbother10
  • 2220 Answers
SOURCE: Motor turns --sprocket or chain doesn't
No clutch on this model electric. I suspect a stripped gear.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If NLA above try here:
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Remington is no longer in production. Often eBay is the only source for ereplacement parts. I suspect this saw was subjected to some severe operation. The motor for any model Remington cannot be found. Look hard at the cost of a new sprocket kit if available, you might be better served with a different saw. We rarely get questions about McCulloch or Poulan electrics, I suspect a much higher quality saw that will nedd few if any replacement parts. Wen is back in production, they used to be a quality product they might be worthy a critical inspection.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 16, 2010
How much to tighten spark plug on stihl chain saw model 028?
General rule is to tighten it by hand, then turn it with a ratchet another 1/8 to 1/4 turn.
May 06, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Makita chainsaw starts and revs then dies
check the fuel filter in the tank is clean it could be blocked
Apr 16, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
No oil to chain stihl ms250
Oil pumper oil gear, needs to be adjusted or replaced. Check out a video how to replace.
Nov 29, 2013 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Chain does not move on the ms170 stihl chainsaw
I assume you have the correct chain for the bar and that the sprocket on the end of the chain bar goes around. Check the bar for any defects like pinches where the bar has been caught. Check the chain drive cogs for any burs on the edges - often happens if the chain has been run too slack and then come off!
Check the chain drive teeth thickness which should be the same as the chain bar can accept. Check also you have the right pitch chain for the drive teeth on the clutch sprocket. Assuming the chain brake is not on then you should be able to move the chain around the bar when all the slack has been taken out. If the chain and bar checks are all ok then there is a problem with the clutch. With the chain brake off the clutch with the chain drive sprocket on should spin reasonably freely. If not then you need to remove the 'E' shaped circlip in the centre of the clutch drum , remove the washer behind it and slide off the clutch drum. Then remove the roller bearing and be prepared to replace it if it will not run freely. Clean out all the muck in the clutch housing and check for anything obviously broken. If all appears ok then put a few drops of 2 stroke oil on the roller bearing and replace it on the shaft. Clean the clutch drum and replace it on the shaft. Then the washer and 'E' clip and re-fit the bar and chain. Re-fit the cover and tension the chain and try again. If that does not do it then there has to be a problem with the chain bar.
Nov 15, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Ht 131 chain does not engage
More information please. Where will the cain not engage in the bar sprocket or on the drive sprocket
Mar 25, 2013 | Stihl Hl Ht Km 87 90 95 100 101 110 130...
Motor runs but blade stops 1" into the wood
Seems like it could be a clutch/drum issue. I have known clutches to break through the threads in the crank shaft so they appear tight but are actually broken. I'd look at the drum assembly to see why the drive to the chain is slipping.
Feb 17, 2013 | Stihl 009/010/011 Clutch/sprocket
Stihl 023 trouble starting & running
Hi, Replace with correct sparkplug. You have a bad plug replace it and you're good to go.
Mar 11, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
The engine will run but chain does not move. what could be the broblem
Right inside of where the bolts are that hold the bar on and the chain tensioner is... there is a centrifugal clutch that engages the chain when the engine revs up...that clutch has gone bad and is not transferring the power from the saw to the chain...
Of that is assuming that the chain is on the sprocket and not sitting off to the side of the sprocket...
heatman101
Jan 04, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a stihl chain saw which although only 3 years old has not been used for 2 years. It started first pull but the cog that drives the chain will not turn and smokes when revved. Is there any easy cure?
remove chain and bar and start up saw if gear turns and revs up than oil bar and chain// if not safety/kickback may be holding back adjust,reset or clean if sticking-- clutch sticking repair or replace
Jan 25, 2010 | Garden
Stihl ms290 chain runs constantly even when idling and when u put the chain brake on it kills the saw
The centrifical clutch is probably rusted (or has a broken spring). You can try a small amount of WD-40 inside the clutch to see it that will break it loose.
Also, be sure that the chain tension adjustment is not too tight!!
Oct 10, 2009 | Oregon Scientific Oregon Chainsaw chain...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
