Question about M-Audio OXYGEN 8 USB Controller
Weird midi Need help my oxygen 8 v2 is sending out some weird midi mssages. If i tweek a knob on a midi instrument the values keep jumping around. In Ableton the midi indicator keeps flashing even tho im not touching the Oxygen 8. Can anyone help plz.
    New Friend:
A few things to try:
1) if your oxygen is connected using a midi cable instead of a usb cable it could be that the midi cable is damaged.
2) you may want to try changing the preset of your oxygen: use the buttons on the oxygen, near the two digits led, to selelct a program between 01 and 15, this will change the values assigned to the knobs
3) you may have some kind of midi loop going on, try going to the preferences in ableton and disable all midi controllers (remote, sync, track) both in and out; then enable only the oxygen for track IN and remote IN which is actually all that you need.
Posted on Jan 30, 2013
2 Suggested Answers
SOURCE: Oxygen 8 Recognized but not working in OSX
i read somewhere, and it worked for me, at least in logic, that when i plugged it into a usb powered hub, it showed up in the audio/midi setup as a keystation and logic accepted its input..... when i had it plugged into the cpu direct (w/o hub) it was useless.... hope this helps....
Posted on Sep 04, 2009
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
Midi-USB cable providing wrong data (notes) to pc? I have a Yamaha YPT 220 / PSR E223 keyboard, and a "generic midi usb" cable wich is actually an Agptek midi usb like cable, (Treble cleff logo ;) ). My...
Make sure that you have the correct midi mapping for your Yamaha. There should have been a software program, called a mid map editor (MME), that came with your keyboard. If you are unfamiliar with this, it is used for changing the values that are sent through the midi cable into your computer (for example, you can change the C0 to be C#0, or any other value, including a numeric value instead of a tonal value). If you bought it used there may have been values changed on midi-trigger presets, which would cause this. If you do have the program, use it to at least investigate that all of the values are in the right places. Often times when someone who is unfamiliar with an MME installs it they open it to see what it is. They change things (not realizing they have done that) and then can't figure out why there is a problem.
Also, make sure your midi cable has the same connections as your keyboard. Some brands make very slight variations to avoid patent issues that may make some cables and instruments incompatible. I have two cables that work fine with certain midi controllers, but when switched they both fail. It's good to make sure the plug ports are clean of dust/dirt, too.
If you are familiar with these problems and they are not yours, you may need to get a different cable. Try to borrow one from a friend to see if the cable is the problem before you buy one. If that still doesn't fix it you may have an internal software or hardware issue. Good luck! I hope I could help.
Aug 27, 2013 | Yamaha Ypt-220 61 Key Personal Keyboard...
Weird instrument clusterl
The clusters in the 1985 Corvette are computer controlled, they are very prone to failure. I recommend you remove the cluster and send it in to be rebuilt. You can also get an exchange cluster for many suppliers of Corvette parts like Zips and others you can find on the internet. The cost was about $300.00 when I had mine done. Click HERE for one such repair center.
Jul 20, 2012 | 1985 Chevrolet Corvette
My m-audio oxygen 8 got wet. is it destroyed?
no not completely if you take it to an electronic store they usually can fix it
Dec 29, 2011 | M-Audio Oxygen 8 V2 Midi Keyboard
Hi i can't get my m-audio oxygen 8 minni key bord to make sound when i plug it in to my proo tools 8 m-powered essential can you please explain to me how it works
Oxygen 8 is a MIDI keyboard only.It does not produce any sound of it's own.
It opperates with instrument software that either plays as a standalone(a self contained program)or as a virtual instrument(VST,DXi)in a Digital Audio Workstaion(DAW).Sonar,Cubase,and Ableton are examples of DAWs.
Jul 10, 2011 | M-Audio OXYGEN 8 USB Controller
I have a 3rd generation m-audio midi keyboard, when i switch it on the numbers keep on rolling.
See if the buttons that scroll the numbers MIGHT be stuck down. Try wiggling them sideways and see if it stops. Beyond this you will need to open the unit and inspect for possible cable problem or debris that might be shorting the signals from the panel buttons.
May 03, 2011 | M-Audio Oxygen 49 USB Midi Controller
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I cant get my knobs or sliders on my oxygen 49 controller working keys, octave and mode and pitch work fine, its just the sliders and knobs
Here is a link that might help:http://www.m-audio.com/index.php?do=products.directlink If your DAW isn't supported it might have a learn function that might help. Make sure you download the latest update.
Oct 18, 2010 | M-Audio Oxygen 49 USB Midi Controller
MY TV IS ACTING REALLY WEIRD. IT WORKED GREAT YESTURDAY. TODAY I CAN'T GET GUIDE PLUS BOX OFF AND IT KEEPS JUMPING AROUND IN THE MENU. EVERYTIME YOU TOUCH A BUTTON IT DOES ITS OWN THING PLASE HELP. MODEL...
i have had a set to do this. it was a problem with not the right amount of voltage getting to an ic. i had a resistor that had changed value once i fixed that it worked just fine
Nov 09, 2009 | RCA F32650 32" TV
Oxygen8 v2
Well do u have the controller CD? Because I bought the MIDI board as well yesterday and found out that w/o that CD installed it won't work. But my problem is the CD won't install on my vista because its not "compatible" any ideas?
May 24, 2008 | M-Audio OXYGEN 8 USB Controller
M-Audio OXYGEN 8 USB Controller Logo
118 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
