I have a speed queen sc35md2yu40001washer that keeps blowing the 2amp fuse as soon as I switch on the breaker it is the fuse where the incoming power goes through before it goes to the transformer
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
Good job tracing the location of the fuses. Now, logically, the transformer is the next thing to check. When power is turned off at the house breaker, remove one of the wires on the output side of the transformer and see what happens when you turn the power back on. If the fuse blows, the transformer is shot and needs to be replaced. If not, go to the next device on the circuit, etc...
Posted on Jan 16, 2013
3 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Bosch Washing machine WFB 4001
well, seems to me that you are using too much juice for the circuit, which implies a SERIOUS issue with the machine. perhaps the motor is locked, or something in control panel is shorted out?
Posted on Feb 27, 2008
richroth
  • 9472 Answers
SOURCE: Maytag LAW9406AAE-serial-11267061QW Blowing breaker
No, the lid switch won't have anything to do with it. First, open the cabinet and look at the wires on the capacitor located on the back of the cabinet under the water inlet valve or on the motor. Check for any shorts. Second, look at the start switch located on the motor, it is where the wiring plug is plugged into the motor for any loose or broken wires. Third, open the top control panel and look at all the switches for ant loose or shorted wires.
Posted on Dec 29, 2010
2002 GMC Yukon blows the TBC 2A fues when headlight switch is turned on
Yukon what ? XL , Denali , 2 or 4 wheel drive ?
My GM service info shows it as a 10amp not 2amp
TBC Fuse #60 10A is fuse #60 same yours ?
May 10, 2015 | GMC Cars & Trucks
Fuse blows as soon as you incert it into yhe ignition circuit on my C300H countax
You have a short somewhere and you need to trace the wiring. For your diagnosis, use "circuit breaker" fuse which will auto-trip/reset if there is a short or high amp draw. I even replaced some of my fuse with circuit breaker.
http://www.autozone.com/electrical-and-lighting/circuit-breaker?filterByKeyWord=breaker&fromString=search&newYmme=true
Mar 11, 2015 | Cars & Trucks
Technics su v550 amplifier.
Check all caps for swelling, leaking. Then check transformers.
Dec 01, 2013 | Cameras
My rooftop a/c unit makes a compressor noise as soon I as plug in my travel trailer. It's a 2009 Outback Sydney edition 310 bhs with a dometic a/c unit I believe. basically with the thermometer switch to...
The system blows cold air when turned to on position but also makes that sound between cycles
NOTE THE ON / AUTO SWITCH BETWEEN GREEN,FAN AND YELLOW ,COOL TERMINALS ON THE THERMOSTAT,
THE FAN SWITCH NORMALLY CLOSED GOES TO LOW, HEAT SPEED, WHILE THE NORMALLY OPEN GOES TO THE HIGH SPEED, COLING SPEED.
BY TURNING FAN ON NOTHING BUT FAN SHOULD RUN..
SWITCHING THE BREAKER TO OFF PRECLUDES THE UNIT FROM DOING ANYTHING !
WHAT CAN IT DO WITH NO POWER!
I switch the breaker to the off position when not using the a/c in order to keep this cycle from occurring. A
Sep 16, 2013 | Dometic Rooftop RV Air Conditioner
Fuse keeps blowing
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and start tracking the wire from the power side of the switch, circuit breaker or the blown fuse receiver, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 02, 2013 | Harley Davidson XL 1200 C Sportster Custom...
99 Carolla pwr windows not working.
You'll have to get someone to trace the circuits to find the short. You can unplug the master switch in the driver's door and use a circuit breaker in place of the fuse or a fresh fuse.
Toyota door switches have a history of problems. If you disconnect the master switch and the new fuse or circuit breaker does not blow, I would try another switch. You may also have a problem with the wiring harness between the door and the post.
If the new fuse or breaker blows, you will need to disconnect the other motors and switches or look for a short in those circuits.
Jun 22, 2012 | 1999 Toyota Corolla
We have a MH7135XEQ1 microwave and the fuse blew on it. We replaced it and it still keeps blowing. What is going on?
You may have a problem with the door switches. There are usually three switches and if the Monitor switch fails or the door isn't closing properly it will blow the main incoming power fuse.
Aug 26, 2009 | Microwave Ovens
Speed Queed AEM677W2 dryer does not blow hot air
Below is a checklist provided by; www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams for DIY assistance.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Firstly, ascertain that you have made a positive heat selection, then read on.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 12, 2009 | Speed Queen Dryers
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
