Question about Samsung RF217ACRS Bottom Freezer French Door Refrigerator
Led lighting in samsung refrigerator
Led lighting does not work
Changed filter on samsung rf4287hars refrigerator. filter icon on LED is still red
Hold Alarm for 3 seconds and this should reset the filter light. Good luck!
Jul 04, 2014 | Samsung RF4287HARS French Door...
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Led light not working in refrigerator
I have the exact same problem. I saw that I can buy a new LED light fixture for about $115 online. I removed my LED fixture and got no DC voltage difference on the wires when the doors were open or closed. This leads me to believe that the main circuit board is the problem. I also saw the main circuit board for about $125. I'd hate to buy the board and it not be the problem. Have you solved this yet?
Nov 15, 2011 | GE Profile PGSS5PJXSS Stainless Steel...
We changed the filter on the icemaker but tye light is still on asking for a filter. now what makes the light go out?
The light stays on, actually. RF265/6/7 models have a blue LED water filter indicator that remains lit in normal mode. After about 5 months [on a 300 gal. filter] the LED indicator will turn pink and then red at about 6 months. Derived from RF266 users manual, hope this helps.
Oct 07, 2010 | Samsung RF265AA Bottom Freezer French Door...
Model rs2534ww side-by-side Samsung frig. After power interuption to the home, interior lights work, but digital display is blank and compressor won't run. How do I fix this?
Regarding Samsung refrigerator model rs2534ww/xaa repair: Basic trouble-shooting from Fixya was helpful, but solution required service call from repairman. (Very few repairmen work on Samsung at this time.) We thought problem was the digital controller, but turned-out was ice maker (!). Repairman explained Samsung has wierd control design that is based upon ice maker sensor. Sensor alone cannot be replaced, required entire icer, which he had in the truck. Icer cost $105 retail ($86 online), but controller would have been $161 retail (couldn't find controller online). Hint: if control panel is "dead" except for (only) the upper (horizontal) LED segment of the right-most refrigerator temperature digit, the problem might be your ice-maker. If you find the ice maker online and can install it yourself, you can save at least $130.
Dec 03, 2009 | Samsung Refrigerators
Doesn't work.
MAIN POWER BOARD IS FAULTY. REPLACE IT.
Jun 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Control panel inactive
Your refrigerator is in demo mode. Review your manual on how to remove it.
Feb 24, 2008 | Samsung RM255LASH Side by Side...
Samsung RF217ACRS Bottom Freezer French Door Refrigerator Logo
18 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
