Adjust screen brightness on ba II plus - Office Equipment & Supplies
SOURCE: how to change the decimal point
2nd
Format
Select a number from 0-9
Enter
2nd
Quit
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: No decimal display on TI BA-II calculator
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Posted on Jun 11, 2009
  • 8073 Answers
SOURCE: is it possible to calculate cube root or higher
To extract the roots of orders higher than 2, you can use the universal power key labeled as [Y to x]. if the exponent is an integer 3, 4, 5, 6 etc.
it gives the cube the 4th power, 5th, 6th, etc.
If the exponent is 1/3, 1/4, 1/5, 1/6 you calculate the cubic root, the 4th root and so on.
When you use it to calculate the roots, the radicand (the number the root of which you are calculating) must be positive, otherwise you may get the result as a complex number.
The syntax of the command is value [Y to x] (1/ order of root)
Ex: cube root of 27 is entered as 27 [Y to x] (1/3)
Posted on Feb 21, 2010
SOURCE: how to you chage from 2 decimals to 4 on the BA II...
By default the BAII Plus displays only two decimal places. This is not enough. Personally, I like to see five decimal places, but you may prefer some other number. To change the display, press the 2nd key, then the decimal point key, and, when prompted, enter the number of digits you would like to see displayed. You must then press the Enter key to lock in your choice. I would press 2nd, ., 5, Enter to display 5 decimal places. Now press 2nd, CPT to return to a blank screen. Problem solved.
One other adjustment is important. The BAII Plus comes from the factory set to assume monthly compounding. That's fine, I suppose, but its better to set it to assume annual compounding and then make manual adjustments when you enter numbers. Why? Well, the compounding assumption is hidden from view and in my experience people tend to forget to set it to the correct assumption. Of course, most people don't recognize a wrong answer when they get one, so they blithely forge ahead. To fix this problem press 2nd then I/Y and enter 1 when prompted. Now press Enter and then 2nd, CPT to return to a blank screen. Problem solved.
Posted on May 31, 2010
  • 102366 Answers
SOURCE: how to set decimal setting?
Press 2nd [FORMAT]. Press 0-8 for the number of digits after the decimal point, or 9 for floating-decimal, followed by ENTER. Press 2nd [QUIT] to exit.
Posted on Feb 26, 2011
Convert decimal to fraction ba II plus
Sorry, but the BA-II doesn't do fractions. It only works with decimal numbers.
Feb 23, 2014 | Texas Instruments BA-II Plus Calculator
How to you chage from 2 decimals to 4 on the ba ii plus
May 20, 2010 | Texas Instruments BA-II Plus Calculator
BA-II Plus payment problem
I just took the battery out and it reset itself.
Nov 28, 2009 | Texas Instruments BA-II Plus Calculator
Jun 03, 2009 | Texas Instruments BA-II Plus Calculator
How to change the decimal point
Hi - You can download the manual from the following link:
TI BA II Plus
Jul 03, 2008 | Texas Instruments BA-II Plus Calculator
153 people viewed this question
k24674
jasbo
jasbo
