Question about GE Dryers
Dryer only runs while holding start button in
G.E. dryer drive belt broke,replaced belt now will only run while holding start button
We have a Maytag Epic dryer with the same problem (Model MED9800TQ0). Pulled out the control board yesterday and saw that the weld had been blown right at the motor relay (burnt marks surrounding the area on the flip side of the board where the relay attaches). Do you suggest we replace the motor relay or just try to re-soder that part on the board? Also - should we be concerned as to how this happened (that it was something elsewhere that caused it to blow)?
Posted on Jan 19, 2013
  • jen32258
    jen32258 Jan 19, 2013
    Sorry - not a solution. I posted this as a new question on a different thread.
agitateme
  • 88 Answers
SOURCE: Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Posted on Jan 17, 2008
AlmostBob
  • 550 Answers
SOURCE: Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Posted on Aug 22, 2008
larryyb
  • 291 Answers
SOURCE: Dryer won't start when press button. If you hold it, it runs.
sound like your even heat board has gone out / send me the complete model number from the panel inside the door and i will see if i can help out / larryyb
Posted on Dec 05, 2008
  • 95 Answers
SOURCE: must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Posted on Dec 30, 2008
  • 686 Answers
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Posted on Apr 18, 2009
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
When I push the start itll start but then right away it stops
If your dryer only runs when you hold the start button in, you probably have a broken dryer belt or it came off inside. There is a belt safety switch near the motor that if the belt comes off or breaks, it won't let the dryer run. There are 2 screws in the top lip of the door area that the door would close against facing up into the dryer top. Remove the screws and lift the top up. If you don't see a skinny black belt around the drum, it broke and fell down inside.
Apr 06, 2015 | GE DVL223GB Gas Dryer
Maytag gas dryer mdg9306awa anits sounds like it wants to start but doesnot
that is the motor,try this,open the door,push the door switch in with one hand and spin the drum with the other hand while someone else pushes the start button,if by moving the drum the motor does start to run the motor is bad,also you have the neptune style maytag and i don't think there's a belt switch in the model so if the belt broke it could be jammed in the motor,try spinning the drum to help it start if that doesn't work unplug the dryer,open the door,remove the two screws that hold the door on and then remove the other two screws on the opposite side,grab the top of the front panel and pull forwards to remove the front panel,you can leave the door on or lift it up and pull out to remove the door,now look to see if the belt broke,if the belt is rapped around the center of the drum then it isn't broke and it will be the motor,that's a good dryer and worth changing the motor on it.
Jan 25, 2014 | Dryers
Dryer not running after start turned
do you mean that if you hold in the start button it will run but when you let it go it stops,if so you have a bad belt pulley switch.it's a safety so if the belt breaks the dryer won't run,all it is is a cherry switch,a black switch with a white button sticking out of it,the belt pulley hits it and pushes the button in but the switch fails internally or the belt is broke,if the belt isn't broke replace the belt pulley switch.
Oct 20, 2013 | GE Dryers
Kenmore HE5 dryer won't start
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
May 01, 2012 | Kenmore HE5 Electric Dryer
Kenmore 63912 will not start.
The dryer has a safety switch for the belt. I f the belt is broke, replace it and all will be good.
Mar 11, 2012 | Kenmore 62802 Electric Dryer
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
Thump
The drive belt broke and the thumping was caused by a flatten roller on the belt tensioner. Replace the tensioner pulley and the belt to get it running like new again
May 25, 2010 | Maytag MDE9700AYM Electric Dryer
Motor runs slow with belt off then will speed up frigidaire dryer
bad motor / holding button will burn it out. ths keeps it on start winding . try blowing the motor out ( delint motor and dryer . ) it will run cooler . motor sounds like it already bad and needs replacement. mm
Dec 03, 2009 | Frigidaire FER231A Electric Dryer
Dryers Logo
138 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
