Question about Crosley Audio Players & Recorders
I need to find parts for crosley cdg8000gwc
Rumble noise when it first starts
  • bud park Jan 16, 2013
    this is a gas dryer
I hear the bearing noise in the engine when ever I start it
ball bearings as in water pump, alternator, idler , ac compressor will be a rumble
heavy knock is a big end bearing
the rumble is repairable by replacing the part , the heavy knock by pulling the engine down
Aug 10, 2016 | Cars & Trucks
What might be experienced by transaxil/transmission bearings wear? Rumbling or vibrations?
Kia is bad with wheel bearings ;.About 80 to 100k they start going bad. You have to check them physically with a dial gauge or know how to inspect them in other manners. They cause a rumbling sound when they start to go bad.
Feb 01, 2015 | 2007 Kia Amanti Sedan
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Oct 11, 2012 | LG DLE2514 Electric Dryer
What would make my washing machine leak water and make a funny noise?
this sounds like the main bearings have worn out (they start to rumble first) when they start to brake up they rip apart the water seals that are between them and the back of the washers drum, and then it starts to leak water, to test them to see if there claped out,,,, open the door and try lifting the top of the drum lightly , if it lifts a bit then drops back when you let go its the bearings going, now spin it by hand and you will here a rumbleing noise or grinding noise, when the washer is running on spin it will sound like the end of the world is coming???? im sorry to tell you this part is not cheep to fix, its 2-3 hours work?
Oct 22, 2009 | Kenmore Washing Machines
Rumbling noise on a low speed between 25-40 miles
Does it sound like an exhaust pipe hitting the floor, or is it a different sound?
Aug 01, 2009 | 2006 Saturn Vue
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Rumbling noise when in 2/3/4 gear
When you think the engine is really powerful even my dads one makes that sound. I think it's the parts like airbags, handbrake area which have degraded due to Aging.
Apr 08, 2009 | 2002 BMW 3 Series
Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
May 30, 2017 | Haier HSA04WNC Compact Refrigerator
My dryer isn't drying my clothes!
soundsmore like a coil kit thats gone bad,located atop the gas valve assy istelf, part number 279834 retails for about $20
Nov 09, 2008 | Crosley CDG6000 Gas Dryer
Crosley traveler turntable noise
Hello attaboy. You may need to check you ac cord if the noise is in turntable, radio, & cassettte mod. If it has a 3 prong plug than you are missing a GND connection, in the cord or inside the unit. If it has a 2 prong plug than take it back or open it up and replace filter capacitors or bridge rectifiers in units power supply.
Sep 19, 2008 | Crosley CR248 Turntable
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
