Question about Hitachi Cameras
Hdc-1209er screen failing can it be repaired
Screen is becoming obscured with black circular marks.camera works ok and produces good results just a problem when you have no view finder
    Genius:
  • 1,019 Answers
Roger, the LCD screen can be replaced and they are listed on E-bay under camera parts under your make and model camera.
Posted on Jan 27, 2013
t00nz
  • 4738 Answers
SOURCE: Screen and viewfinder only shows black....no picture
Are the pictures also coming out black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 02, 2009
SOURCE: Nikon E5700 digital camara.
There is a service advisory out for Nikon E5700.
t has come to our attention that in a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras, an electronic component may, in some instances, fail affecting your camera's performance and/or operability.
While only a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras are affected by this advisory, if your camera presents symptoms that can include (1) images with a strong color tint, (2) images that are totally black and/or (3) images with visible defects, Nikon will, upon confirmation that the problem is associated to this Service Advisory, service your camera free of charge.
link to info is here: http://www.nikonusa.com/Service-And-Support/Service-Advisories/index.page
Posted on Jun 03, 2008
  • 285 Answers
SOURCE: View finder
Ok. On your viewfinder, there might be a round dial. Turn it to adjust focus. Otherwise, sometimes viewfinders are like that... blurry, especially electronic.
Posted on Apr 19, 2009
SOURCE: The lcd and finder view are both black. The
The CCD fault is a known issue with Sony. My F717 was purchased in 2004, and developed exactly the same problem you described a year ago. Just before junking it recently (Dec 2009), I did a Google search and found that Sony will do free repairs. Their website makes this issue clear, and their online fault reporting system worked well in the UK. I got a printable freepost label, packakaged up the camera and sent it off. It came back a week later fully working again at absolutely no charge.
Posted on Feb 08, 2010
  • 73 Answers
SOURCE: turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Posted on Jul 25, 2010
Lumix DMC-LX3 screen black when finger on the flash section
This is probably a deliberate electronic interlock to prevent photographs being taken when the flash is obscured. Why not just refrain from putting your fingers in inappropriate places ?
May 11, 2017 | Lumix Cameras
Zoom lens won't open when i switch on
  • check if the batteries are fully charged.
  • try resetting the camera.
  • zooming motor has gone bad. have it replaced.
May 13, 2014 | Hitachi Cameras
Hdc sd300 camcoder. when i swith it on, screen is black. i cant see anything. just black screen and recording ony sound.
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Nov 04, 2010 | Panasonic PV-GS500 Camcorder
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Dark LCD Screens and no flash
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Feb 06, 2008 | Canon PowerShot A70 Digital Camera
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Cameras Logo
Top Hitachi Cameras Experts
DocZachary
DocZachary
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
