Question about Lexmark Wheelwriter 15 Series II Typewriter
How do you clean the platen in an IBM Wheelwriter 15 Series II?
  • Lexmark Master
  • 3,594 Answers
Remove the platen by squeezing the plastic lathes at both ends.
Clean it with mineral spirits and fine sand paper.
DickyO
Posted on Jan 16, 2013
  • 3594 Answers
SOURCE: IBM Wheelwriter 10 Series II
Perhaps the paper tray is not seated properly or even in backwards, check that also the black latches do crack and not properly latch, if so you may need a new platen.
Posted on Nov 07, 2007
  • 3594 Answers
SOURCE: IBM WheelWriter 10 Series II not functioning.
Could be many things. Take off the case and look for parer clips, staples or other debris on or under the PC board or in the power supply.
DickyO
Posted on Mar 09, 2009
  • 3594 Answers
SOURCE: IBM Wheelwriter 10 Series II 6 Beeps 1,2,3 Blinking
Check in the area where the printwheel is installed for paper or other debris. If it does the same thing with the printwheel out then it is probably a printwheel sensor.
DickyO
Posted on Jul 14, 2009
  • 3594 Answers
SOURCE: I have an IBM Wheelwriter 15 Series II that when I
You probably have a broken plastic print solenoid cap. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Jul 08, 2010
  • 610 Answers
SOURCE: I have an IBM Wheelwriter 15 Series II and the
Make sure both tabs on the rear of the cartridge are in their respective slots. If that does not work, try pushing down on the black platen roller on both ends. If one side is not locked in place, you will get half letters.
Posted on Oct 20, 2010
Testimonial: "Perfect! Thank you so much! My boss wanted to throw it away so I'm glad I saved her some money!"
Why do I have vertical lines on paper going through a IBM Wheelwriter 15 Series II?
Try removing the platen by squeezing the black plastic latches at both ends and lifting out the roll. you will probably find debris on the tray or build up on the rolls.
DickyO
Jan 16, 2013 | Lexmark Wheelwriter 15 Series II...
Maquina de escribir ibm WHEELWRITER 15 SERIES II "ESCRIBE SOLO LA MITAD DE LAS LETRAS, LA PARTE SUPERIOR"
Push down firmly on both ends of the platen it should snap into place. If the latch is broken the platen will need replaced.
DickyO
Sep 05, 2011 | Lexmark Wheelwriter 15 Series II...
I have an IBM Wheelwriter 15 Series II and the ribbon needed replaced so we replaced it, now when you try to top it just types the top half of the letters??????
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
IWhen i turned it on it only types half the letters/numbers etc
If it is only typing the top half of the letters the platen may not be fully seated in the side frames, push down firmly on both ends of the platen it should snap into place.
DickyO
May 11, 2010 | Lexmark Wheelwriter 15 Series II...
It sounds like the Platen roller has popped up out of place on one side. Try pushing down on the black rubber roller (platen roller) on both ends. It is held in place by two black plastic clips that are attached to the roller ends and one of them may be broken. But usually it has just popped up on one side and pushing it down usually solves this problem.
Mar 18, 2010 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 15 Series II Typewriter Problems
The right side of the platen has prabably come unlatched. Just push down on the right side of the platen, (black roller the opaper goes around) it should clunk down into place.
Oct 30, 2008 | Lexmark Wheelwriter 15 Series II...
ONLY TYPES TOP PART OF THE LETTER IBM WHEELWRITER 30 SERIES II
The most common problem is the platen (black roller) gets out of position. Be sure the black latches are aligned wuth the side frames then push down firmly on the ends of the platen it should snap into place.
DickyO
Aug 27, 2008 | IBM Wheelwriter 30 Typewriter
IBM Selectric II
When you turn the platen by hand is there a ratcheting noise?
If not the ratchet release lever may be in the wrong position or not engaging the platen. orthe spring for the detent arm is broken if it's not the lever you probably need a tech.
DickyO
Jul 16, 2008 | Lexmark Wheelwriter 15 Series II...
I assume you had the platen out and now it is not seated all the way in. Be sure the black latches are aligned with the side frames then push the platen FIRMLY down.
Oct 27, 2007 | Lexmark Wheelwriter 10 Series II...
Lexmark Wheelwriter 15 Series II Typewriter Logo
116 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
