Question about Toshiba Satellite A60 Notebook
Toshiba satelite m70 wont turn on with battery charger plugged in
    New Friend:
  • 3 Answers
Try taking out the battery, then with the charger plugged try toturn on the computer
Posted on Jan 17, 2013
Pyrhyc
  • 2028 Answers
SOURCE: TOSHIBA satelite wont turn on
If you have tried a new power supply and taking out the battery and it still won't start, then the problem is with the power management system on the motherboard. This means that the motherboard will have to be replaced. Check into your warranty, being that it's only 10 months old, it should still be under warranty. If so, then get it to them to be fixed asap, before they decide your warranty doesn't cover it.
Posted on Jun 26, 2008
abhi_patil
  • 569 Answers
SOURCE: I can not get any sound from my Toshiba Satalite pro M70 laptop.
please check your speakers, try to insert headphones and hear if u can hear any sound, try to install drivers
if u can hear the sound with headphones means there is a problem with ur internal speakers
Posted on Nov 24, 2008
Geekman
  • 32281 Answers
SOURCE: how can i downlaod a free sound driverfor my toshiba laptop
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Posted on May 28, 2009
  • 29 Answers
SOURCE: toshiba satellite a40-s270 won't turn on
Either the power supply is not working or the battery has failed and will not hold a charge. If the laptop is 3 or more years old, the battery is the likely suspect.
Posted on Feb 12, 2010
  • 2567 Answers
SOURCE: why wont my Toshiba Satellite A25-S207 turn on? i
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 06, 2010
I forgot my bios password on my toshiba satelite M70
Forgotten BIOS passwords can be extremely difficult to reset or otherwise solve said problem.
The first thing to try is removing the CMOS battery from the motherboard of computer for a solid 30 seconds. Doing this will certainly clear the CMOS. After performing this simple procedure, try to boot your computer as normal, and see if the BIOS password is gone.
If it is not gone, you'll need to get a copy of your motherboard's manual and find out if there is a jumper procedure for clearing the BIOS password. This will usually entail setting a jumper, turning on the computer, waiting a certain amount of time specified in the manual, turning off the computer, and finally removing the jumper you set to clear the BIOS password.
After those two possible fixes things get pretty hairy, and I would suggest you simply contact the manufacturer (not the retailer) to see what can be done, if anything.
Apr 08, 2014 | Computers & Internet
Satelite m70-181 audio drivers
u must download it from microcoft .... create an account and downlod it :)
Dec 27, 2013 | Amstron Toshiba Satellite M70-181 Laptop...
Where is the motherboard battery on a dell precision m70
Remove the Battery from the Battery Compartment. Remove the small panel cover. (Access Door)
Right there.
http://support.dell.com/support/edocs/systems/wsM70/sm/index.htm
Click on Coin-Cell Battery.
Regards,
joecoolvette
(Make sure the AC adapter { Charger } is not plugged into the laptop)
May 21, 2012 | Dell Precision M70 Notebook
No screen display on toshiba M70 laptop
Try plugging in to the external monitor again and toggling the video output using FN+F5 a few times. If it eventually displays on the external monitor, but nothing ever displays on laptop screen after trying this a few times, the issue could be with the laptop screen, in which case you'd want to have it checked by a repair shop:
http://forums.computers.toshiba-europe.com/forums/thread.jspa?threadID=62553
Apr 15, 2012 | Toshiba Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My toshiba s\atelite a135-s4527 wont turn on and
Could be the "resume" battery that has died - its an internal battery shrink wrapped in bright green plastic on tosh's normally - you might be able to get to it by unplugging stuff, battery, cd rom etc etc....unplug it and plug it back in again, if it comes alive again order another. I went on a toshiba laptop maintenance course years ago with a company that i worked for and that error that youre seeing was the fix....see if that works...
Aug 07, 2009 | Computers & Internet
My satelite r15-s829 tablet laptop battery went aprox 10 days without a charge while shut off. Saturday I received a new ac adaptor, upon plugging it into the laptop an amber light in plug in icon on the...
This appears to be a problem with the ac charger its saying that ur charger is underpowered and cannot charge ur laptop take a look at ur older charger and buy the same brand and that should help out its a common problem that pops up for some that replace failed chargers
Dec 15, 2008 | Toshiba Computers & Internet
Nov 24, 2008 | Toshiba Satellite A105 Notebook
Solve a probleme
Sounds like a defective battery pack or a charger that isn't as it should be.
Aug 19, 2008 | Toshiba Computers & Internet
No power in toshiba satellite pro m70
You need to check ur power sockets,
ur charger whether its working,
and test the battery,
also try to switch it on when there is no battery attached to it by just pluging the charger straight
Mar 17, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite A60 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
