Question about Datacard SP35 Printer
Replaced Color Ribbon now the printer doesn't print all colors on color badges...Only cycles through once
After change the ribbon the print not get all coloures
Posted on Jan 30, 2013
5 Suggested Answers
  • 13 Answers
SOURCE: printer printing one color
Go to smart driver printer tool box, then select
brightness 0
contrast 0
sharpness 0
cyan -------centre----------
magenta ------centre----------
yellow -----centre-----------
From toll box select clean printer
Go to advanced setup
select monochrome
Down -3
Left 140
By doing all the above setting hope your problem will get solved , check the ribbon also , move two to three rounds change in the ribbon by manually .
Posted on Aug 08, 2009
  • 36 Answers
SOURCE: datacard sp35 is saying it has a k ribbon but
Most likly problems in order of most common,
Bad RFID radio tag in take up spool of printer ribbon,
Bad RFID reader in printer
Printer need firmware upgrade to help in reading weak tags.
Fist would try a new ribbon, if that does not get it will need service. Contact MIdWestIDSolutions.com
Posted on Mar 18, 2010
  • 36 Answers
SOURCE: Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Posted on Mar 19, 2010
RNS-Systems
  • 120 Answers
SOURCE: THe datacard sp55 color card
The printer needs to be serviced, The Monochrome issue could be related to a problum with the RFID chip in the take up wheal of the ribbon, but the duplex offset can only be adjusted by an authorized service provider using a special password and diagnostic tool.
www.TulsaBiz.net offers a depot service.
Posted on Sep 01, 2010
When I print on my HP Color LaserJet 2600n Printer the far right(1 inch) of the page is faded and is unable to be read. I have replaced the ink cartridge but it doesn't help
Have you cleaned the print heads? There should be a program that came on the drivers disk that includes a "service" tab where you can align and/or clean the print heads automatically. If they are particularly dirty and have never been cleaned, you may have to run it through two cycles to get it right.
Oct 05, 2011 | HP Color LaserJet 2600n Printer
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
Hello, We have a problem with our EVOLIS PEBBLE
reload the ribbon make sure you load correctly and set the correct type of ribbon on the driver make this and reply to me
Aug 24, 2011 | Evolis Pebble Color Card Printer
Epson stylus photo r300 removed print head, flushed out all nozzels with water, dried everything, reasembled everything, including the flat ribbons, two different times. After dozens of times trying to...
If an inkjet printer has not been used for some time and several print head cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 24, 2011 | Epson Stylus Photo R300 InkJet Printer
Hi I work in a restaurant and we have a Epson TM-U220A Model M188A printer. The last few days the printer has not been printing on the White receipt paper. We've tried replacing the ink and it doesn't do...
If this is the thermal head model, you will need to have the print head replaced. These were also sold under the Dell label, so finding a used replacement printer may be more economical. If it takes ribbons, you will need:
Ribbons
This printer needs a ribbon cassette to print receipts.
EPSON ribbon cassette, ERC-38 (B) (Life: 3,000,000 characters / Color: Black) EPSON ribbon cassette, ERC-38 (P) (Life: 4,000,000 characters / Color: Purple) EPSON ribbon cassette, ERC-38 (B/R) (Life: 1,500,000 characters / Color: Black)
(Life: 750,000 characters / Color: Red)
You can order replacement parts here: http://www.umd.com.au/itd/products/spareparts_epson.html
Thanks
Jan 08, 2011 | Epson TM-U220 Matrix Printer
Installing only one printer cartridge
suggest you install a color cartridge and set up the printer for color. When the color cartridge runs out of ink, you should be able to continue printing in black only.
Mar 19, 2010 | HP PSC 750 All-In-One InkJet Printer
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
Datacard SP35 Printer Logo
509 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
james laughton
james laughton
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
