Question about Toshiba CF32G50 32" TV
Toshibe CF32G50 - Red Flashing Light
I have a Toshiba CF32G50 and the Red light on the front of the set flashes when I turn on the set. No Sound or picture, just the flashing red light.
    Problem Solver:
  • 5 Answers
YOUR SET IS TRIPING MAYBE POWER SUPPLY IN TV SET
Posted on Jul 15, 2007
SOURCE:
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
Toshiba Cinemax Series HD Black screen - no sound
The red light flashing is usually the set detecting a short, to know if I can or cannot help I need to know the model number of this Toshiba.
Dec 16, 2012 | Televison & Video
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
My toshiba tv is flashing a red light and wont come on
REPLACE THE FLYBACK ( AROUND $70.00 FOR PART
Dec 06, 2008 | Televison & Video
TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Oct 31, 2008 | Toshiba CF32G50 32" TV
Toshiba tv
Is the red light flashing or solid?
If the red light is flashing it is the signal board is bad part number 75001688 $425.00 - $475.00 depending on supplier.
If the red light is solid then you signal cable has come loose or has went bad.
Sep 10, 2008 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
Feb 09, 2008 | Televison & Video
Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Jan 27, 2008 | Televison & Video
Televison & Video Logo
513 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
