Question about Janome Memorycraft 6500P Computerized Sewing Machine
TD init error code
When I turn it on, I get this error code.
I get an error 05 on my SINGER Futura xl-550....i have it set up to embroider and when i turn the machine on I get the error and the arm does not move
You need to find out what error 05 means. Usually, you will find that information in the troubleshooting section of the owner's manual. If not, you can search for:
Make Model error code 05
You may need to contact Singer Support if you can't locate an error code list.
Feb 28, 2018 | Singer Sewing Machines
I have a Singer Futura Quartet SEQS-6700 sewing machine. Keep getting error code 16, but there is no explanation in the product manual. Can you help?
Generally the error message is due to "some" electrical overload. It settles itself most times by turning off the sewing machine for a few seconds to allow complete shut-down and then turning it back on. It the error message returns, it is best to visit your qualified local technician.
Nov 07, 2014 | Sewing Machines
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
Aug 26, 2014 | Singer Sewing Machines
Janome MemoryCraft 6500. What does error message "BM init error" mean? What does it take to fix it?
That's an initiation error. I would call Janome direct and ask them.
Dec 02, 2012 | Sewing Machines
Problem with Juki DDL-5550N-7 Sewing Machine, Error Code E24
El Drv se refiere a la tarjeta interna que controla el motor, est? se encuentra da?ada.
Email: ingcegadan@gmail.com
May 11, 2012 | Juki Sewing Machines
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
Auto Punch Installation Problems - Saying Internal Error
There was a problem with the inital discs distributed with the machine. Try downloading the autopunch from the singer website (its hidden at the bottom of FAQ) and loading it exactly as per the instructions provided ( you will need to print them). If you do not have access to the internet I suggest you contact who ever you purchased it from and ask them to help you.
Nov 26, 2007 | Singer CE-200 Quantum Futura Computerized...
Janome Memorycraft 6500P Computerized Sewing Machine Logo
98 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
