Question about Dell Inspiron 9100 Notebook
I just replaced my dell laptop screen and i have a squiggly line
Squiggly lines
Check and replace all the filter capacitors at its main power regulator section circuit.
May 22, 2013 | Televison & Video
Lg r405 laptop screen flickering
most likely a loose connection if it is flickering.. if there are red squiggly lines usually means driver issue.. and if there are blue banding lines, typically means the chip is overheating/desoldering.
Mar 07, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
Video Card Ribbon Problem? Squiggly Lines on Monitor
It can be that the video card in bad or any electrical part need to be fix and i recommend to send it to a repair shop.
May 12, 2012 | HP Pavilion Computers & Internet
There are 24 black lines (one inch to 3 inches in length). coming up from the bottom of my Dell Inspiron 1545 laptop computer. After awhile the lines start getting squiggly, turn purple and spread out...
Try to connect an external monitor to the laptop if the lines are there then it's the video chip on the motherboard. But if you don't see ant lines on the external then it's the LCD on the laptop and it can be replaced. If you can't perform the work yourself take it to a local repair shop.
Mar 04, 2011 | Dell Computers & Internet
Small Rectangles or squiggly lines on screen
bad RAM on graphics card. replaces graphics card
May 14, 2010 | BenQ G2110W 21" Monitor
I'm having problems with video playback
Hi. Does it happen in all videos titles or just one film? If it only happen in only one video then the film or video is corrupted. If it happens in all videos when you play then try reinstalling the graphics driver. Hope it helps!
^_^
May 05, 2010 | Dell Computers & Internet
Multiple squiggly lines fill the LCD screen, after
Sounds to me like your inverter has gone bad. Typically it's situated just below your LCD. To get to it you will have to take out the screws around the LCD bezel. It's a long, skinny circuit board that the LCD plugs into. You can usually find a replacement on Ebay. Just be sure that you're ordering the correct part, otherwise it may not fit or work properly. I've also had times when the entire LCD was going bad and the display was full of squiggly lines. It's hard to say which one is the cause. I would try replacing the inverter first. That part is usually much cheaper than the LCD is.
Apr 10, 2010 | Toshiba Satellite M60 Notebook
YELLOW AND BLUE SQUIGGLY LINES ON THE RIGHT SIDE OF THE SCREEN
Hi Fkanode.
The failure(s) in your TV is related to a part called light engine or optical block and Sony TVs are known for these kind of failures with the video showing with different colors or lines.
Check the link provide for more info or if you would like to try fixing the TV yourself.
Let me know if you would need further assistance.
Mar 07, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Dell Inspiron 9100 Notebook Logo
21 people viewed this question
Alun Cox
