Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I HAVE A KODAK 3 IN1 ESP C310 AND WHEN I GO TO PRINT ANYTHING IT PULLS IT TO ONE SIDE BUT THERE IS NO PAPER STUCK AND A MESSAGE APPEARS SAYING IT IS OUT OF PAPER
    New Friend:
I have the same problem on my printer, the same as yours, and have not come across a solution yet. Please e mail me at anthony.leftwich@sky.com with the solution if you have come across one. Many thanks
Posted on Jan 27, 2013
SOURCE: Paper jam in a Kodak ESP- Printer
i had the printer jam issue when there wasnt a real printer jam.
if you push the print cartidges off to the right, then reach in and push down on the cleaning head that is located on the left on the inside, it pops back down into place and voila, printer jam error message fixed.
Posted on Jul 04, 2009
  • 295 Answers
SOURCE: Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
Posted on Jul 27, 2009
  • 295 Answers
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Posted on Jul 28, 2009
  • 295 Answers
SOURCE: paper jam message on esp 7 kodak printer
open rear access door and check out if there is any tape in and around the rollers or any torn paper or any staples there.. turn printer upside down and oprn bottom p[aper tray check out if there is any paper stuck there. take power cord out of printer and again insert it back. ur printer will work fine
byron21
  • 151 Answers
SOURCE: kodak printer 3 in1 says its paused when i try to print from pc
Basically the problem is caused by the printer spooler which is a printer system file that was installed on windows XP
For this problem kindly try doing the ff:
  • click START then select RUN
  • Type net stop spooler
  • Type net start spooler
  • Then try printing
  • if problem still persist call 1800 421 6699
Hope this will help
Thanks
Byron
Posted on Sep 01, 2009
My Kodak ESP C310 printer will not print the full page only the heading & footer lines when I do print preview
Does it hapends with all the documents or only one ?
The text or graphics might be too large ?
have you tried to set the margins ?
Oct 16, 2014 | Kodak ESP C310 All in One Printer -...
Bidirectional support disabled
See this... http://support.en.kodak.com/app/answers/detail/a_id/1294/~/error%3A-bidirectional-support-is-disabled/selected/true
Jun 28, 2014 | Kodak ESP C310 AllInOne InkJet Printer
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Sep 12, 2013 | Kodak ESP C310 AllInOne InkJet Printer
Can't print to my Kodak ESP C310
have fun I hate Kodak drivers go wired some operating system are not compatable with the disk go to web site and find a better driver if that doesn't work get a tech to check settings
Feb 07, 2013 | Toshiba Satellite Computers & Internet
Printing multiple page pdf on kodak esp c310 AiO
I had exactly the same problem as you! Whenever I printed anything of more than 1 page the paper jammed. I now know why... When you go to File>Print in Adobe reader, the print window displays a load of options. Simply uncheck the 'Print on both sides of paper' box. This worked for me! Hope it works for you!
Eoghan12
Jan 31, 2012 | Office Equipment & Supplies
My kodak esp c310 tells me paper jam how do i fix it
Turn the Printer on
Wait for the error message
open the printer
move the ink cartridge a little bit to the right
on the left side you have three gear wheels
move the frontmost forward to move the printer carriage it should go easy.
Close the Printer and press OK to test the printer.
If it not works move the gear wheel further and further and maybe backwards to remove stuff which block the carriage
Nov 28, 2011 | Kodak Office Equipment & Supplies
Kodak esp 3250 printer applemac 10.6 os airport express. printer tries to print but no print appears on paper
Sounds like print head needs replacing, try the troubleshooting guide on Kodak website, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although if not they are expensive
Jan 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer says 'Unable to detect paper width'
The paper tray has some "fingers" that detect the paper.
Remove the paper and tap the sensors a few times to make sure they are not stuck.
Use lots of mamper, not just one sheet so that there is enough weight to press down on the sensors.
Perhaps it is Earth's gravity that is malfunctioning today :)
Sep 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
135 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
