Question about Xerox WorkCentre 3550 Laser Multifunction Printer - Monochrome - Plain
Workcentre 3550 diagnostics mode - Xerox WorkCentre 3550 Laser Multifunction Printer - Monochrome - Plain
Xerox 7328 diagnostic entry procedure
To enter the CE mode:
  1. Press and hold the 0 key for 5 seconds, then while still holding down the 0 key, press the Start button. The CE Access Number screen will appear.
  2. Enter 6789 and press Confirm.
  3. The top most area of the UI display will be reversed to let the user know that the mode has changed to the CE mode.
Jul 30, 2014 | Xerox WorkCentre 7328 Multifunction laser...
How do I change the cartridge region from a xerox workcentre 3550
The toner cartridges have a small CRUM chip fixed on the end of each tube. If you change them from a previously empty cartridge then it will still show empty. You just can't fool them.
Good Luck.
Jul 14, 2014 | Xerox Corporation WorkCentre 3550 Laser...
My workcentre 3550 multifunction printer is constantly printing the configuration report, how do i fix that?
Anthony,
I'll assume your printer is wasting paper.
Firstly remove the paper, that should stop it, then try and enter Centreware, check the www.Xerox.com website as to how to do that. From there you will have more control from there.
Replace the paper as a check, and hopefully the problem will be sorted.
Good Luck.
May 24, 2014 | Xerox Corporation WorkCentre 3550 Laser...
My workcentre 3550 multifunction printer is constantly printing a configuration report, how do I fix that?
Anthony,
Please remove the paper and see what happens next.
Open up the print driver and look to see if the queue is full of prints not sent, If so, delete them from there.
Check over the information the configuration page if any thing looks irregular.
Check the settings against the copy first printed when the printer was first installed, it might be tucked inside the machine panels.
This problem looks like finger trouble to me. Further investigation is needed. When your sure everything is as it should be, replace the paper in the tray again.
Good Luck.
I have connected my laptop to my WorkCentre 3550 and loaded all the necessary software for the two to work together. They just don't seem to talk to one another. I open a document, chose to print, a
Hi Gary. I presume that you use the USB type connection for your printer. In your computer appears the message that indicate the detection of a new hardware?
Jul 22, 2017 | Xerox WorkCentre 3550
My Xerox WorkCentre M123 does not enter in more ways administrator password is 11111 and x-admin right but as soon as I enter the settings Administrator freeze (crashes) same thing with Internet access,...
  1. Enter UI Diagnostic Mode.
  2. Press the Log In/Out button on the Control Panel
  3. Select System Settings.
  4. Select Common Settings.
  5. Select Diagnostics.
  6. Select NVM Read/Write.
  7. Enter location 700-171 and press Confirm/Change. This is the current password. You can provide this number to the customer, or set the location to the default value (11111) and allow the customer to enter a new number from Tools mode.
May 26, 2011 | Xerox Office Equipment & Supplies
I need to restore NVRAM from the WorkCentre 2424.
1. From the System Setup menu, go to Information --> Troubleshooting --> Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
If that doesnt work try below.
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads 'Beginning Service Mode Initialization'. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. You should find it in the function sub menu.
Jul 16, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre 3550 Laser Multifunction Printer - Monochrome - Plain Logo
76 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
