How many peices of paper come in a ****?
How many peices of paper come in a ream?
    Guru:
  • 269 Answers
It depends on the brand but there are usually between 480 and 520 pages per packet of A4 paper.
Posted on Jan 16, 2013
What is the cause of most paper jams?
Usually three things
A small piece of paper torn off from a previous jam.
Damp paper. Keep your reams in the airing cupboard.
Worn or shiny rollers. Clean them with a damp cloth and a little detergent.
Oct 11, 2016 | Canon All-in-one Laser Printer Mf6500
How to load paper ?
Open the paper drawer, open a ream of paper, run a finger across one edge to fan the paper and then place the paper in the drawer.
Aug 02, 2016 | Office Equipment & Supplies
When making a copy the paper gets all crunched up inside the machine and stops the printhead
Sometimrs the paper in the tray collects moisture, try opening a new ream of paper and put in some of it to see if that works.
Apr 05, 2016 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Paper keeps jamming. what can i do to stop this
Just take the paper out turn it over and replace it. Paper has a bit of warp and needs to be placed in the correct orientation. There should be an arrow on the ream.
Oct 30, 2015 | Canon PIXMA MX700 All-In-One InkJet...
Will not pull paper into printer
Good evening my name is Steve.
A suggestion ....if your printer has never been serviced, chances are the Paper feed-tires are "glazed".
Over time the paper dust that is conviently for free in a ream of paper gets trapped on the surface of the Feed tires. This will result in no-traction, or false paper-jam.
if you have a little alcohol ,Q-tips and some spare time a patients, you can save a $65.00 cleaning bill...I hope this helps, Best regards,Steve
Aug 18, 2015 | Office Equipment & Supplies
How do i get to the vacum hose to goes inside the wheel well (or so it seems to) on the drivers side.ii
new peice [plastic] vac line duct taped to coat hanger.ream old line out.phillips screwdriver.insert hanger and pull through from inside.splice to old ones.if you dont want to pull a/c control head.small rubber line 1/2inch splice.
Aug 25, 2014 | Cars & Trucks
Paper not feeding through properly
If paper ream was humid or the paper stick to each other then there can be a feeding problem. Loosen the sheets by ruffling the sides and put in the feeder, adjust the side aligners to fit paper snugly but not very tight
Oct 20, 2013 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark E250dn , asks me to add paper but paper tray is full, where do i check for the sensors
There is a sensor relay arm under the body of the printer in the hole created by removing the paper tray.
Look for a long thin peice attached to a spring assembly.
There is a wire that plugs in to the relay it may be loose.
You might also remove the paper, push the metal peice of the paper tray into a locked postion and then replace your paper
Oct 11, 2013 | Lexmark E250dn Laser Printer
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Wasting paper
Press the User tools/counter button. Select the fax option. Locate confirmation page and turn it off.
Jan 19, 2009 | Ricoh Aficio 450 Copier
326 people viewed this question
k24674
jasbo
jasbo
