What files do a hitachi L32HK04U L support as it wont play my file from my usb stick
I have put some avi files on my usb strick and tried to watch them on my tv but it says it does not support the file. Ithen converted the avi files to video and it still says it cant support then.. so the I converted them to mp4 and same again.. so then I converted them again to MPEG and it only let me play them for 3 mins. please can you help as its getting me down and I want to watch my films on my new tv .. many thanx
    Scholar:
  • 70 Answers
This tv will not play , wmv, avi, mov, mkv, or divx, the hitachi uses the xvid codec only, which means your video file types must be mp4, and not the h.264 mp4 either....but true mp4 video, if you have a connected usb drive full of movies, best bet is to download "youtube downloader" (free off the internet) install it to your PC, and use the convert feature to convert your movies to the ipad video mp4 setting, with the "same as original " quality ticked....and convert all your movie files to the xvid codec your tv wants, youtube downloader can convert anything, any filetype even flash. trust me this works 100% i know, i have the Tv, and i do know about codecs and scaling..and metadata....do this will be your best bet guys !!! happy viewing
"> ONLY FOR HITACHI TV's
Posted on Feb 27, 2014
imadejoolaff
  • 27 Answers
SOURCE: External Hard power is on but does not show up on my pc and does not seem to be running
Does it happen to be a Maxtor II? I had a very similar issue with my external and it devastated my backup program.
If the power light is coming on but not being recognized by the OS, your first step is (as you said) trying a different USB/Firewire cable. If that does not work and you don't care about voiding an expired warranty, you can open the case and remove the HDD. It will have several screws in the back; just undo them and slide it out. Try hooking the HDD up through IDE (or SATA if equipped) and after powering up, go into BIOS and see if it shows up on the IDE(SATA) list. If it doesn't, then as far as I know, your only other option is to try a pricey data recovery service.
Posted on Feb 07, 2009
iklln6
  • 35 Answers
SOURCE: Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Posted on Jul 15, 2009
  • 191 Answers
SOURCE: cancel ''write protect'' on USB memory stick
If no physical switch, then check the software that came with. Some sticks have a software component that recognizes when you plug the stick in and gives you options for viewing and launching applications from the stick. There may be controls you can use to change the write protect.
If not, or you can also try, opening a view to the stick from Windows Explorer and just delete files from there as you would from any drive. Windows will prompt you to confirm delete. I wouldn't delete any auto-load or setup apps that would be used to connect to another computer.
Posted on Oct 05, 2009
laikexpert
  • 281 Answers
SOURCE: My usb intelligent stick installs ok and shows
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 02, 2010
  • 567 Answers
SOURCE: My Hitachi Microdrive 4gb hard drive seems
H there this mean a file is corrupt and you need to repair the damage file,you can do this by using a recovery disk for the computer if you have one.If you don't do not have a recovery disk for the computer you can use the operating system disk to repair it,please follow these steps:insert the operating system disk into the drive,restart the computer, press F12 and choose boot from CD save and exit.As the computer loading it will ask you to press any key to boot from CD, press any key, a blue screen will appear while its loading, when it get to the first set of options you will press enter to continue. when it get to the second set of options it will ask you to install the operating system or repair it, choose repair and follow the steps from there, this should solve the problem. But should backup your files before doing this even though no file will be lost but its better to backup just in case something goes wrong.
Posted on Jun 16, 2010
Playing .avi files on USB stick directly to TV?
as you did not provided the manufacturer (brand), model or version - we do not know if your tv is capable of direct play of .avi files, you need to go to the manufacturers site and check what supported formats are.
Feb 24, 2015 | Televison & Video
Sanyo tv avi unsupported file
Maybe you have reported that AVI and some other formats not supported by Sony TV, in this case how can we play AVI files on Sony TV from USB flash drive? Please don't worry, now we will share the best AVI to Sony TV converter - Pavtube Video Converter with you, which can help you to convert AVI files to Sony TV USB supported format, and then you can play videos on Sony TV with compatible format.
Reference: Watch MP4/AVI/MKV Files on Sony TV from USB
Apr 12, 2013 | Sanyo Televison & Video
Eh5000 wont play movies on usb stick
The TV can only play a specific format of video. You may be using MP4 files while the TV can only view 3GP or FLV formats; just try downloading a converter (I've used FLV Converter on Windows XP for years, works fine and very simple) and changing the file format.
Jan 30, 2018 | Samsung Electronics Samsung 40" EH5000...
Canot play media on television from Hitachi 500GB Touro Mobile USB 20
Check the supported movie files that can be played on that tv then look at the file and see what type of file it is. I recommend using MP4, WMA or AVI files
Feb 16, 2012 | Hitachi 500GB Touro Mobile USB 20 HDD Hard...
I'm trying to play movie files through my toshiba lcd tv via a usb and it won't work. i've tried converting mvi and wmv files to mpeg or avi and still won't play. can you tell me which type of file works...
You have not mentioned the TV model #.. If your TV does not play avi. files I am sorry to tell you it does not support moving pictures -- it only supports MP3 music files and JPEG picture files !!. Try these two to confirm.
Mar 12, 2011 | Toshiba Televison & Video
I have an Hitachi with mini dvds. They play back on the camera but not on the computer. HELP!
First find the format of the video.
Insert the video cd to the computer and right click the video file and the click the properties menu, watch the file type(i.e: .flv , .avi ,.wmv)
Basically the hitachi saves in mpeg2 or mpeg4 type.
Use the GOM player to play the video Or there are many more players available to play that video.
Sep 15, 2010 | Hitachi Video Cameras
Picture sides cut off when watching avi files
My new LG LCD is not syncing the video and audio when playing avi movies on either USB stick or HDD.
Dec 28, 2009 | LG 37LC5DC 37 in. LCD Television
Can't play AVIs.
dear friend
you are missing a codec
just download klite codec pack from link below
klite
thanks
Apr 12, 2009 | Computers & Internet
I cannot format my kingston datatraveler it says its protected
hello evelymont i found a solution to our problem!!try to download HP USB Disk Storage Format Tool and try to formta the flash stick to fat32 file system!!And after that you're ready to store any file you want unless you put them in a folder first because of the fat32 file system and not saving them on the root for exaple if you want to store an avi file at E: where E: is your kingston usb data traveler save the avi like this e:/name of the folder/avi file, and not in the root e:/avi file!!
that 's it !!congrats for your buy!!
Nov 21, 2008 | Kingston Technologies 512MB DataTraveler I...
USB Port
I am not getting any sound from my koss model ks3101 through the speakers
May 30, 2008 | Philips LX3750W System
Computers & Internet Logo
750 people viewed this question
David Payne
David Payne
