Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Inlet/Outlet light flashing
When starting any program, the water comes in and the after a while the water is removed, however it is at this point where the program gets stuck as no more water is fed in to continue with the wash. This is when the Inlet/Outlet light flashes. The Inlet filter has been checked and cleaned, the outlet non return valve has been checked and cleaned
  • triplet63 May 06, 2008
    There is water remaining the bottom of the dishwasher and the inlet/outlet light is flashing and nothing will work. The pump had made a noise earlier and after cleaning the filter and running the pump for a minute the noise disapeared and it seemed to be working fine. The cycle shut down with the water in the bottom and now nothing happens.
  • Anonymous Sep 26, 2008
    I have the inlet/outlet flashing but the start button is not on (yellow light does not come on) the plumber has checked the pipe and it's all ok and still won't work.
  • 83 Answers
Check your overflow level switch wich is located behind front kickplate on right hand side
Posted on Feb 24, 2008
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Whirlpool wfs 1071bd. Washing machine starts , drain works , then start/pause indicator lamp flashes. Wash light is on. No other lights on. Taps are on , and nothing is happening. Any ideas?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump
Mar 23, 2013 | Washing Machines
My whirlpool Model wtw4850xq is not working. The spin light keeps flashing and it won't do anything when I push start other than lock the lid.
Jan 24, 2013 | Whirlpool WTW4850XQ Washing Machines
ARFX125 h20 symbol flashing
Jan 21, 2013 | Washing Machines
My omega washer dryer owd6000wa won't start start light not flashing
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jun 27, 2012 | Kenmore Washing Machines
Hotpoint wma62 normal sign lashing red green sign flashing machine will not start what is the solution ?
Jun 05, 2012 | Hotpoint Washing Machines
No water entering machine. machine had stpped, as there was a piece of cling film blocking the outlet, this has since been removed but machine will not wash.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect but in this case the inlet and outlet must be checked.
Thank you for using fixya.
Sep 01, 2011 | Bosch Dishwashers
Machine fills with water, then the drum wont turn at all - just lots of little clicks - eventually all the lights that are on flash - just got a red flashing light on the start/pause button when we tried...
Try and check the inlet valve or replace , check this link:
Aug 22, 2011 | Zanussi ZWF12070 Front Load Washer
HDW201WH will not start. Lights are on but when pushing start button it jusr flashes and does not start. Pump outlet been cleaned
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
http://www.espares.co.uk/advice/dishwashers/a/3
Jul 12, 2011 | Haier Dishwashers
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
1,077 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
