Question about KitchenAid KIRD801HSS Kitchen Hood
I have a 4 year old Kitchenaid downdraft KIRD801HSS stops when attemting to retract
The unit has worked fine for all these years. It has been kept up very well. Recently when trying to raise the telescope, it sticks and I have to push the button numerous times to get it to rise all the way. It also retracts very slowly when attempting to close. I have sprayed silicone spray on the rails and WD-40 to attempt to lubricate it.Their may be built-up grease down inside the tracks. How does one remove and/or clean the rails without removing the unit? I'm afraid this dragging motion will burn out the motor. Help!!
SOURCE: Self cleaning attempt has shut down the control panel.
You need an air flow kit, part 81911788 and a professional to install it.
Posted on Jan 09, 2010
SOURCE: Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Posted on Jan 22, 2010
SOURCE: Kitchenaid downdraft retractable vent
Your drive motor arm is not making contact with either of the two limit switches at 6 and 12 positions. Your arm may be loose, gear stripped, broken bracket. Turn off the power at the breaker panel and remove the vent pipe cover box (4 nuts) see what is going on inside. Tellstar
Posted on Feb 03, 2010
  • 254 Answers
SOURCE: oven cleaning mode quit in middle of cycle. unit
prob blew the high limit thermostat in the rear of the unit, pull unit out remove back panel and check that thermostat for continutiy with a meter.. hope this helps
Posted on Feb 06, 2010
Downdraft up and down
Hi do you mean the air is increasing and decreasing on its own
Feb 22, 2008 | Thermador CVS30R Kitchen Hood
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Vent doesn't rise
See this link for information on this.
Raise the Vent
May 23, 2010 | KitchenAid KIRD801HSS Kitchen Hood
Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Downdraft vent won't stay down. Push the button and it retracts normally, then pops right back up?
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Aug 27, 2009 | KitchenAid KIRD861HSS Kitchen Hood
Right side stopped working (KPTT809)
I had the same problem with my Kitchenaid toaster which is 4 years old. I called Kitchenaid and they said that this model now has a 5 year warranty and they have replaced the toaster for a new one. What a fantastic company. Try giving them a call.
Jul 06, 2009 | KitchenAid KPTT890 Pro Line 4-Slice...
Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Mar 01, 2008 | KitchenAid KHTU165RSS Stainless Steel...
KitchenAid KIRD801HSS Kitchen Hood Logo
54 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
