Question about Vacuums
Brush does not work
The brush is not working the light does not come on, the reset button does not correct the problem, the belt is ok.
  • 66 Answers
If the motor works and the brush dosen't turn then I would check the belt and as far as the light goes it might just be blown hope this helps
Posted on Jan 24, 2009
I had just changed the belt and I turned it on to see how it was working , and I noticed that it sounds like the motor is working hard
Take the belt off machine, try machine with the belt off, if motor sounds OK, try spinning the brush before putting belt on, if brush does not spin freely, see what is clogging it.
When brush spins freely, reassemble correctly and try.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 24, 2016 | Kirby G6 Bagged Upright Vacuum
Brush not working, green light not lit. have taken apart and put back together but still not working.
Hi Carol, Many models have a reset button (breaker) on them to protect the motor that turns brush. Look for one of these on yours and reset it. Should be on the outside of the unit.
This could also be a missing or worn belt. If you forgot to look for this when you had it apart, open it up again and make sure there is a rubber belt running between the motor and the pulley on the brush. If it's there, try turning the brush while holding one side of the belt with your fingers, to see if the brush pulley slips easy under the belt. If is does, you need a new belt. Make sure it's not plugged in... : )
Hope this help....
Mar 01, 2016 | Vacuums
My electrolux vacuum has a red light that won't turn off and my brush roll won't work
Check the belt and the end bearings are free by hand. (electric off plug out) if not free remove plate to access roller/brush, remove clear any obstruction (Hair/string/thread) replace and test. ensure you site belt back on to spindle and roller/brush correctly...
Aug 22, 2014 | Electrolux Vacuums
Dyson DC14 reset button location
go to http://content.dyson.com/support/?basketTotal=0.00&basketQty=0&logged=false
proceed with your models, and see videos or troubleshooting or video for to se the reset button.
God bless you
Aug 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Reset button for Eureka 431 bagless upright???Where is it?!
If the red light is one the says "check brushroll" then you have to take it apart to find out what the problem is. It might be that the roll has too much stuff rapped around it so you have to take it out and clean. It could also be the rubber belt is not properly in place. Once you take the bottom off the belt should go on the far right side. Those are the only things i can think of. I have had mine for 3 years and have never seen a reset switch. Usually when my light comes on it is because there is a lot of hair rapped around my brush roll.
Jan 17, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Eureka boss 5893A brush roll does not work
you have to prss the pedal and lean it back the brush roll wil enguage
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Reset button
Do the brush rolls turn ok? The brush roll motor may be bad.
May 19, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Rainbow SE power nozzle
If the brush is spinning ok, and the belt isn't slipping, then probably the circuit breaker is bad, or the motor is causing the problem.
Oct 23, 2007 | Rainbow 75th Anniversary Canister Vacuum
Vaccum wont work
There is also a reset button on the side at the bottom. Good luck.
Oct 14, 2007 | Vacuums
Vacuums Logo
124 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
