Question about Emerson Microwave Ovens
I am not able to get the unit to cook, I have to unplug it and then only the number 1 cook time and the number six cook time work
  • Emerson Master
  • 9,047 Answers
You have a failed membrane keypad.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 17, 2013
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Model NN T964SF inverter
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: some numbers don't work
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: The Cook Time I use to work, not it wants a code
Is it possible that some cleaner got into the controls? That'll kill them quickly.
Hopefully it will dry out on its own. I'd unplug it overnight.
If not, then either there is moisture on the control board (which can be dried or allowed to dry) or in the layers of the membrane keypad.
But the membrane keypad may not be available any longer. It is part number WB27X287 and if it still available, it may take a week or so to get it, it will probably be about $150-180, and you can try to order it from the Pros here, the Sears Parts Direct Web site image-4235112-10659157 or from Encompass here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We do board repair, so let us know via our site if we can help further.
Posted on Jan 02, 2011
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
How do you set the power level? The model number is: JVM1730DM1WW The serial number is: MM901698B
Assuming your touch pad is working properly, press Time Cook (for cooking) or Time Defrost (for defrosting) and then type in the length of time that you want the microwave to operate. Then press Power Level and type in a number from 1-10. Finally press Start. Depending on the GE microwave, the Power Level button may be above 2 or to the left of 0. (I've seen both keypad designs depending on when and where the microwave was manufactured.) If you press Power Level before setting the cooking time, the unit will reset when you press Time Cook or Time Defrost.
GE has the manuals for some of their microwaves on their site. See http://www.geappliances.com/service_and_support/literature/ and enter the model number in the search engine.
I hope this helps.
Mar 02, 2011 | GE Microwave Ovens
The Cook Time I use to work, not it wants a code and if I put in a number it will start. But I can't set a cook time or power level. The Cook Time II works ok, except I can't use the number 1; defrost...
Dec 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Buttons aren't working. It says Press Start and when you do it either doesn't work or add second to the cook time, and never cooks
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still does not work, you likely have a failed membrane keypad.
We would need your full model number to help you further or give an estimate.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. "Ed" Miller, AS-EET
prototech@usa.net
Aug 18, 2010 | GE Microwave Ovens
I have a GE Spacemaker and used defrost for the first time at Thanksgiving. Now I can't turn it back to normal cooking. Can you please help me?
If that doesn't work, leave it unplugged for maybe an hour.
If it still doesn't seem to work, I'd consult the owner's manual for a quick refresher. You can find it
here.
If it still fails to cook at full power, I'd say your magnetron is failing.
And if so, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your previous symptoms:
"I have a GE Spacemaker and used defrost for the first time at Thanksgiving. Now I can't turn it back to normal cooking. Can you please help me?"
Nov 28, 2009 | GE Microwave Ovens
The power button is not working,i do not use this button very often, less than 1 time a week. i have had the oven 3-4 years
First try a hard reset.Unplug it a couple of minutes, then plug it back, set the clock, and try again.
A typical key sequence to cook for a minute a 70 percent power would be:
Cook Time (or "Cook") > 1 > 0 > 0 > Power Level (or "Power") > 7 > Start
It varies by brand and model.
If it still doesn't work you may have a failing keypad. If so, please leave it unplugged or leave the door open when it's not in use, and of course please do not leave it running unattended.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So please reply back directly to me with your brand and full model number from the tag in or on the unit for more help or free do-it-yourself tips or an estimate if required.
William E. Miller
prototech@usa.net
Sep 26, 2009 | Kenmore 63672 Convection/Microwave Oven
Timer issues
Let us know what you find out.
If you still have trouble, please reply back with your brand and model number so we can help you. Otherwise...
Aug 08, 2009 | Goldstar MV-1501 Microwave Oven
Does not cook - time counts down extremely fast
Then let us know if the hard reset does not fix it.
and please reply back with your brand and model number so we can help you.
Feb 06, 2009 | Goldstar MV-1526 Microwave Oven
Chefmate microwave oven won't start, only flashes numbers.
Well I had the same problem. It made me start unplugging a microwave when it wasn't in use, which is always a plus.
When it does the whole 6666 thing, press 5 and then stop/reset. It usually allows me to input what I want after that.
Good luck people.
Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
