Question about Garden
Hi my McCulloch mac 70 keeps loosing power,I have changed the fuel filter,spark plug and air filter the mixture is right but still won't run right,any ideas?many thanks Barrie.
    Sergeant:
  • 322 Answers
Check the muffler for any type of obstruction first. Then I would check the diaphragm in the carburetor to make sure it isn't starting to stiffen up. If that doesn't help it may be that it is just old and tired
Posted on Jan 16, 2013
Testimonial: "Many thanks,it was the muffler very useful information,thanks again,kind regards Barrie."
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
2009 v star 1300 won't idle runs rough
Hi, Snakeman_982 the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Erratic idle so confused Yamaha Star Forum
http://www.starbikeforums.com/forums/49-v-star/9084-v-star-acting-very-sluggish-sputtering.html
Yamaha XVS1300A 2007 Service Manual
OEM parts for Yamaha
YAMAHA XVS1300A Owner Manual
Dec 27, 2012 | 2009 Yamaha V Star 1300 Tourer
McCulloch mcc1635a chainsaw won't run. Acts like it is starving for fuel.
take off the muffler and try it there is a screen inside that get plugged up with carbon you can open the muffler to clean it
Jun 03, 2012 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
Saw won't start without starting fluid.
Sounds like you have a compression problem. Starting fluid will fire at a much lower compression than a gas/oil mix so that's why it will start with it. When the motor is running you get a little more compression because the piston is coming up so fast. You should check the condition of your cylinder wall and piston & ring. If they are damaged at all you loose compression which directly affects starting and running power.
Mar 28, 2012 | McCulloch Garden
Why does my 1995 mazda protege sputter and die when i accellerate
An engine needs three things to function correctly: (1) the right amount of fuel; (2) the right amount of air; and (3) an appropriate spark. I would also add a fourth point for a gasoline engine: appropriate compression in the engine. A worn-out engine won't perform well, even if items 1-3 look good.
Poor fuel flow is one possible cause of poor performance. A clogged fuel filter is only one possible cause of that. You might have a weak fuel pump, although with the electric fuel pump on this car, that would either have the car running or not running at all, not running poorly. You might very well have a clogged fuel injector--gas is getting there, but an inappropriate amount is getting sprayed into the combustion chambers. You might also have a clogged fuel intake screen inside the gas tank--the fuel pump might not be able to **** up enough fuel.
Air is another possibility. Check your air filter. Is it clean? A clogged air filter will cause incomplete combustion when you step on the gas because not enough air is getting in to create a proper air/fuel mixture. A simple test for this is to try running the car--VERY BRIEFLY--without the air filter. Does it run better? You should not run your car without an air filter for any longer than diagnostic reasons--sucking dust and dirt into your engine is a fast way to ruin it--but it's an easy and essentially free test you can perform. Or you can just replace the air filter if the one you pull out looks nasty.
A final consideration is spark. If you have a weak spark, you won't get as strong an explosion in your cylinders, yielding less power and stumbling. Or, if the spark comes at the wrong time, you'll have the same problem. You can check for a strong spark by taking a spark plug--an old one, a new one, one that doesn't even match your car, and using it to test the spark coming off each of your spark plug wires. Attach the plug to a wire you disconnect, ground the tip of the wire against exposed metal on your engine, and look for a nice healthy blue-white spark. If you see a yellow or orange spark, that's not so good. That could indicate a weak ignition coil--or also old spark plug wires that are leaking voltage. Spark plug wires should probably be changed every 5-6 years; they're not a lifetime part of your car.
A final consideration I didn't list previously is that you may have a bad O2 or other sensor that measures and adjusts the air / fuel mixture. A bad sensor will force your car's computer to operate on a default profile designed to let you limp home. However, it won't perform particularly well.
Good luck; I hope this gets you pointed in the right direction.
Mar 09, 2012 | Mazda Protege Cars & Trucks
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
My 1967 bel air has a 250 l6 and won't start, it tries but just won't kick over, what should I look for first?
need 3 things to run
1. fuel
2. air
3. spark
loose any and it wont run, pull a plug wire off and crank it over.
does it spark? if yes good if no do same test with coil wire
disconnect fuel line stick hose in a bottle turn over, pump fuel? yes? good, no either filter clogged or pump bad
Jul 14, 2011 | Chevrolet Chevy Cars & Trucks
Engin starts but won't stay running,I'v changed the fuel and spark plug
I would check the fuel inlet hose for holes, cracks or tears first. If it has any leaks the carburetoe will be drawinfg in air and cause the problem you describe. If it's good you may need to remove the carburetor and give it a good cleaning and/or rebuild.
Jun 26, 2011 | McCulloch Garden
PowerMac by McCulloch PM425AV-18 38cc. I have replaced the line from the fuel mixture tank to the primer bulb & replaced the primer bulb. Now the chainsaw won't keep or looses the prime. Now...
Are you sure you have conected the pipes the correct way round, the fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, nearest to the alloy pump cover, the other conection off the carb goes to the shorter conection on the back of the primer, the longer pipe on the primer goes back to the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chainsaw starts then quits right away. half choke. has fuel and bar oil chain is free and runs.
Our mini-Mac saw seems to require some fiddling with the choke as it doesn't have a primer button, but once it starts firing, the choke can be opened fully after a moment or so. Check the fuel filter, air filter, and muffler for plugging. Check the fuel line for decay or other problems. Make sure the carburetor fasteners are tight. Check the spark plug for blue, snappy spark (gapped at 0.020"). Hope this helps!
Aug 16, 2010 | McCulloch Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
