Question about Watches
Grandfather clock won't chime
Clock won't chime,
  • 744 Answers
SOURCE: Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Posted on Mar 29, 2009
gemineye61
  • 831 Answers
SOURCE: I'm just wondering if someone
I know nothing about clocks, but found a great website for you.
http://www.howtorepairclocks.com/
Good luck
Posted on Aug 19, 2010
SOURCE: Have a Galleria Grandfather clock thats chimes are
try movinging the hour hand to the time the chimes are chimeing at
Posted on Sep 07, 2010
gemineye61
  • 831 Answers
SOURCE: I have a Seth Thomas
Thanks for contacting FixYa.
I wish I had an aswer for you but I dont. Here is a link for a repair man that has an 800 # toll free to call for estimate.
http://clock-repair.net/site-map/seth-thomas-clock-repair/
Best regards. Jewel
Posted on Sep 14, 2010
SOURCE: Pearl Grandfather Clock, Model 1151
Hi pbardua,
I suggest that you need to remove the the first Left weight and see if the clock will run normal again since you mentioned it was not connected before you took possession of it.
Remove the Left Weight and see first if thing will run fine on the clock, must be a reason why the first owner never connected the Left Weight.
Won't hurt to try.
Posted on Jul 17, 2011
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    G.E. Grandfather clock The Adams
    I assume you have looked on the Internet to find the manual. Even with all the trillions of things you can find, probably no one has uploaded that manual yet. I had a clock shop for over 30 years. Most grandfather calendar dials can be set by using a NEW pencil eraser. Try to use it near the center of the dial, not on the outside edge. Move the dial clockwise. I suggest a new pencil eraser because a used one can leave smudges on the dial.
    Oct 30, 2017 | Watches
    Edward Meyer 31 Day Grandfather Clock manual
    I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
    Jan 23, 2012 | Watches
    Coaster model 900723 grandfather clock doesn't keep time
    Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
    Nov 20, 2010 | Watches
    We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
    Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
    Nov 19, 2010 | Watches
    I have a Seth Thomas Grandfather clock with three different chimes and chimes at every 15 minutes. The problem is it is chiming 2 hours shorter than the actual time. Example say it is 11:00, it is...
    Best regards. Jewel
    Sep 13, 2010 | Watches
    Have a Galleria Grandfather clock thats chimes are off. How do I get them correct? Bought it at an auction and did not get any information with it. It chimed correctly in the beginning.
    I suspect that the mechanism needs cleaning.
    Take a look inside and if there is the slightest sign of dirt (particularly on the striking mechanism) then it should behave properly after cleaning.
    May 01, 2010 | Watches
    The pendulum stopped swinging...the clock and chimes work well
    Hi
    This clock short of needing a full service may simply be out of beat.
    Taken from my web page located at:
    http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
    "HOW TO PUT YOUR CLOCK IN BEAT"
    -Included below is a 10-second sound <snip> of a clock both in and out of beat.
    IN BEAT ////////\\\\ OUT OF BEAT
    · Turn on your sound and click on the clocks above for a sound clip.
    -One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
    -I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
    -As I'm sure we now realize a clock must be in beat but not always level to function properly.
    · Above is the verge with a slip clutch.
    · Often found on Grandfather clocks and requires only a long swing to get it in beat.
    -To get the clock on the right side in beat you would need to push the verge assembly to the left.
    -If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
    R/ David
    Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
    Mar 29, 2009 | Elgin 0518709FA
    Watches Logo
    257 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
