Question about Canon PowerShot S3 IS Digital Camera
Write Protect When I put in the 2gb SD card i bought with my camera it has started saying card locked, even though the slider on the side of the card is in the unlocked possition.
    Genius:
  • 2,985 Answers
Get tge store to check this out - may be a faulty card.
Posted on Aug 01, 2007
Says sd card error
Are you sure it's an SD card? Even though SDHC cards will also fit into the slot, they will not work in the A540. If the card is larger than 2GB then it will not work.
Feb 03, 2013 | Canon PowerShot A540 Digital Camera
Olympus tg-310 says write protect even though sd card is not on write protect
SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
You may have a software write protection enabled.
Oct 19, 2012 | Olympus TOUGH TG-310 Digital Camera
When I try to delete a picture/video it says WRITE PROTECT with a ! point
Hi there, Can you take pictures on it? It sounds like the SD card is locked. If you take the SD card out, you should see a slider on one of the sides. Push it up to unlock the card - then you should be able to delete. If it is already up, then there is a write protect option on your camera you need to disable. Alex
Jun 04, 2011 | Olympus Stylus Stylus 820 µ Digital 820...
Card locked
An SD memory card usually has a little white slider on the outside of it. I says in small letter, with a little arrow "LOCK" . Push the slider in the opposite direction of the arrow i.e. to unlock it.
If this is the case, then the camera should be able to communicate and write to the card.
There is also the possibility that the device in the camera which detects this slider is damaged. In that case the camera should be repaired. I think, though you will be OK moving the slider.
There is also the possibility that the card is corrupted. See the Link below
http://www.normsoft.com/kb/idx/49/157/article/
I hope this has helped you.
Happy New Year,
Best, Mark
Jan 01, 2011 | SanDisk 2GB microSD Memory Card
When I now try to use a 4gig memory card it always says the card error or card locked. I have tried card in both positions but it still says it is locked. I have tried with 3 different 4gig cards. What...
You may be restricted to using only SD cards, and many 4gb cards are actually SBHD. My sister had this problem with her camera and by putting in a new 2 gb SD card, her camera worked fine. You may need to shop online in order to find an SD card, but they're widely available online. It costs about the same for 2 2gb cards as one 4gb even though they aren't as convenient.
Nov 11, 2010 | Canon PowerShot A540 Digital Camera
I cant take delete, or move photos from my sd card, If i try to do anything with the images on the card when its plugged in to my computer a pop up comes up saying 'Cannot move 4267_180627790516_589680516...
is the card lock slider on? look at the card, there is a tiny switch that says in tiny letters lock, is that moved to the lock position? the little slider is on the left side of the card with the SD Logo label
May 07, 2010 | PNY 2GB microSD Memory Card
I need to unlock a Sandisk SD card, I've just
If you've already tried the slide switch, see this link for additional things that you can try.
Mar 18, 2010 | SanDisk 2GB microSD Memory Card
How do i unlock my sd card
There is a slider on the left hand side of an SD card which sets the card to Locked (lower position) or Unlocked (higher position - i.e. towards the top of the SD card). The first step is to check the position of this slider.
Note that the position of the slider does not affect the SD card in any way - it trips a switch inside the camera (or other SD reader). The slider MUST be in the upper position or the camera will say Card Locked - so if the slider has fallen off (they are very fragile!) the camera will assume it is in the Locked position.
Jul 19, 2009 | Praktica SlimPix Digital Camera
I bought my Kodak Easyshare C310 a few years ago and has been working fine. I bought a new SD card as lost my old one, and when I inserted into the camera it said the memory card was full (wasnt as brand...
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Kodak EasyShare C310 Digital Camera
Memory is locked on the camera
ok so on sd cards there's a slider on the side of it. this has an arrow (usually pointing down) that says lock next to it. make sure the slider isn't on the side that the arrow points to.
hope this helps ;-)
Apr 04, 2009 | Sanyo Xacti S650 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
