Question about Samsung ML-4551ND Printer
Smps fan locked - Samsung ML-4551ND Printer
SMPS fan locked
the smps power supply needs to be replaced. it should clear with a power cycle but it WILL come back.
May 12, 2014 | Xerox Phaser 3600DN Laser Printer
Tip
How to check the SMPS in Desktop Computer while the system is Dead Condition
1.Remove the all power jacks from Motherboard before check the SMPS. 2.after removing the SMPS then follow the below steps
i) Short the Green and Black wires with a small conductor(wire) in 20 pins jack of SMPS ii)Now plug the main wire into SMPS
iii) On the SMPS Now see the SMPS fan whether it is running or not if the fan will be run then the SMPS has no Problem else SMPS will be Problem. 3.Change the New SMPS with same ratting of Watts
on Apr 17, 2010 | Computers & Internet
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
My computer will not power up?
Check the SMPS fan working. Check the mains cord. Then open the PC. Short green wire with black wire by using paper clip while keeping the mains ON. The SMPS fan should rotate. If not, replace the SMPS. Also check the CPU fan.
sonsunny
Jun 15, 2011 | Dell Dimension 2400 PC Desktop
SMPS Fan Locked
Samsung Printer ML-4550N SMPS FAN LOCKED ???
What is this problems???
Jan 25, 2011 | Samsung ML 4551NDR - printer - B/W - laser
Seams like fan not working
if the fan is not working first you have to test the smps remove the smps connector from the motherboard and short the green and black pin it he smps fan is working then the smps is fine coneect the smps connector to the motherbord and switch on the computer still not working then remove the four pin connector from the smps and restart your computer if irts working the problem is in your motherboar
Dec 30, 2010 | Dell (6F858) Cooling Fan
No power coming on intel desktop motherboard d845
Check the power supply to the motherboard i.e the SMPS, if it is working the fan of the SMPS will rotate. If the SMPS is ATX you can check it without connecting it to the motherboard. Unplug all the SMPS power connectors from the motherboard and then short circuit the green and the black wire of the 20pin connector of the smps, if the SMPS is working the fan of the SMPS will rotate. If the SMPS is in good condition and working, than it might be a problem in the internal circuit of the motherboard.
Check the process here:-
http://www.jestineyong.com/?p=267
Jul 19, 2010 | Intel D845GVSR Motherboard
My Smps is ok, when i switched on smps fan and processor fan not on
Check Following Instruction:
1. If your SMPS ok, Check 20 pins cable connect properly to the motherboard, or Fan 4 pin connect to the motherboard.
2. And Start your Motherboard. It will OK.
Apr 13, 2010 | Intel Motherboard
How to replace exhaust fan on Compaq Presario SR1103VM
what kind of pc are u using plz? is the maain case with screws
Apr 02, 2009 | Computers & Internet
Color Printer fan error
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Mar 25, 2008 | Samsung CLP-600N Laser Printer
Samsung ML-4551ND Printer Logo
54 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
