Question about Panasonic CT-36SL14 36" TV
Tv wont turn on, neither with remote or manually. outlet is fine
  • jacob926 Jan 26, 2009
    TV WONT TURN ON. NEITHER WITH REMOTE OR MANUALLY. OUTLET IS GOOD.
    TV IS A PANASONIC CT-36SL13
  • 350 Answers
Dear FixYa Customer,
If you want to take your PANASONIC CT-36SL13 TV in for service go to this Panasonic Site and enter your zip code and they will recommend a Technican near you:
PureFlat
-TVs/model.CT-36SL13">http://www2.panasonic.com/consumer-electronics/support/Televisions/Tau-Series-PureFlat-TVs/model.CT-36SL13
If you want to attempt the repair yourself FixYa will do it's best to help you.
I went to Panasonic myself to look for parts, entered CT-36SL13 and got a "not available" from them
They do list parts available for a CT36SL13G @
https://www.pstc.panasonic.com/Epartr/PartsList.asp
I wouldn't count on these parts working for your TV unless your TV is an exact match to this CT-36SL13G model # !
Hope this is helpful.
Good Luck!
tv wont turn on - 6968f2c.jpg Please rate this!
Posted on Jan 26, 2009
  • Jack Iaria
    Jack Iaria Jan 26, 2009
    Thank You for Using FixYa!
    Brigadier General:
  • 8,619 Answers
Hi!
Your Panosonic set has failed either in the power management circuits or, more seriously, one of the deflection systems has failed.
Do you hear a turn on sound when you power it ON or the current monitoring system is detecting excessive current drain from somewhere in the set and turning itself off These are among the most serious problems that a set can have.
  • Rylee Smith
    Rylee Smith Jan 26, 2009
    Also chekc out for any blown fuse or burnt components or try to plug the TV in a different socket.
    Also, you can try a full reset, which requires at least 4 to 6 hour disconnect from the power.
    Thanks
    Rylee
  • 11,896 Answers
The power supply is most likely the issue, BUT you should check a couple more things before having it replaced.
1. check that the fuse in the back of the TV is good.
2. Try and reset the tv set by pressing and holding the up and down volume buttons at the same time
3. Try resetting by holding power button in for 15 seconds.
4. Do a hard reset by leaving it UNPLUGGED for at least 4 hours
If the tv does not reset , than your only other choice is to have the power supply replaced
  • 10,594 Answers
Its power supply failure in TV and need to be checked by qualified TV tech.
If you have basic electronics knowledge and have good soldering skills, you can give it try.
Posted on Jan 25, 2009
  • 818 Answers
Power supply issue. You need to replace it, do you need to have the service manual for it.
Sergio
  • 10,515 Answers
ICS MIGHT HAVE BLOWN....
 U MIGHT NEED TO VHANGE ICS OR CAPACITORS........USUALLY IT HAPPEN DUE TO VOLTAGE  FLUCTUTATION.
ADVZ U TO CALL PANASONIC CUST. CARE.......IF U R NT CONFIDENT TO PLAY WITH BOARD.
2 Suggested Answers
vortash
  • 431 Answers
SOURCE: Wont turn on; remote/tv power switch inoperative
hi I am Vortash .. burning smells usually mean Power supply or line output .. flyback problems .. this is probably one of those jobs only an engineer should look at .. voltages on the line can exceed 400 volts and are highly dangerous the line output from the transformer depending on the type of tube can be up to 25,000 volts .. so best leave this one to the proffesionals Regards Vortash
Posted on May 18, 2009
Model number- IWT3206 A, when i plug it into an outlet the curcut board screams and wont turn on what can i do to fix it it has to be simple
The circuit board has burnt out. At this point you will have to use a universal remote or some type of cable remote to operate your TV.
Nov 08, 2011 | iLO IWT3206 TV
I pressed the power button, but the tv wont turn on
Please check if the power cord is connected properly in the wall outlet and in the TV. Check the wall outlet. Has it got power? Check if there is red light when the power is switched on at the wall outlet. If there is red light then press the power button. Does the TV turn on? If not then your power button is defective and requires replacement as it is not making contact. Also please try to start your TV WITH THE REMOTE CONTROL. At times it helps.
Feb 12, 2011 | Sanyo Televison & Video
Won't turn on/no power. Worked fine until i turned it off as usual, went to turn it on, no power either from "ON" button or remote. wall outlet works fine, tried it in other outlets, no luck.
Well, I used to be an authorized Apex repair center and absolutly could not get a part for a tv. You may just have a bad H.O.T. ( horizontal ouput transistor) which is what I needed. I don't even know if they are still in business. Good luck.
Oct 23, 2009 | Apex Digital AT2402 24" TV
The TV just does not turn on. It is plugged in, and the outlet works. It worked fine when it was turned off, but will not turn back on by the TV button or the remote.
Tries change the IR remote control board.See if it work,if it dosen't it ur IC that near the front that connected IR board connection is dead the IC is dead.
Sep 02, 2009 | RCA TruFlat 27F520T 27" TV
Apr 25, 2009 | iLO IWT3206 TV
My sharp tv wont turn on
I don't know if you have this problem but I had a similar problem aswell. My TV remote and my universal remote wouldn't turn on or perform any of the funtions as they should. This is what I did to fix it: 1. unplug the TV from the power outlet. 2. take the batteries out of your TV remote. 3. press the power button on the TV remote, and then press every other single button one by one from left to right (as if you were reading a book). 4. plug the power cord back in the power outlet. 5. replace the batteries in your TV remote. 6. try turning on the TV using the factory remote.
These steps, as weird as they sound, worked just fine for me. My TV is now responding to my remote and my cable remote is able to control the TV again. No, I did not loose the universal (cable) remote's TV codes. FYI. the steps mentioned above were performed using the TV native remote (factory remote). Hope this will work out for you as well. And if you are wondering how I knew this would work, well I saw the same steps on another website (sorry I can't remember which website it was) and decided to give it a try before I took the TV back to BestBuy for warranty repair...which would have taken like two weeks.
Jan 01, 2009 | Proscan PS27500 27" TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
TV won't turn on
the power supply of your tv is not working,coldsolder the mainboard of your tv,
Apr 26, 2008 | RCA 32F531T 32" TV
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
TV won't turn on
If the TV wont go on with the manual button on the front panel, then you have an issue with the tv set. Try a differant wall recepticle. Or unplugging it overnight. If it wont go on with the button on the front of the set after this is tryed, then its time to go to the repair shop, as the set has a power supply problem or a problem in the HI voltage/sweep circuit. Good Luck
Jun 17, 2006 | Sony FD Trinitron WEGA KV-27FS320 27" TV
Panasonic CT-36SL14 36" TV Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
