Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
KITCHENAID DISHWASHER STUCK IN WASH CYCLE - KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
It can be the issue with defective float switch. The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. One more thing, if your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Posted on Jul 23, 2016
SOURCE: Kitchenaid Superba Dishwasher - Restarts wash cycle
sounds like bad console or bad control board.
Posted on Nov 04, 2008
aborcass
  • 2651 Answers
SOURCE: Lights flashing on clean. Program does not take.
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Posted on Jan 10, 2009
  • 120 Answers
SOURCE: My Kitchenaid dishwasher seems to be stuck on the
check to see if you don't have it on an extended wash cycle setting. After that, check to see if the dial is stuck.
Posted on Oct 05, 2009
SOURCE: KitchenAid KUDR01TJ Dishwasher Makes noise. E.G.,
Called a contractor.
Posted on Oct 29, 2009
  • 128 Answers
SOURCE: Kitchenaid dishwasher will not turn on or drain
Float valve is jammed.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Posted on Mar 17, 2010
Kitchenaid dishwasher stuck on wash cycle
I'd you wish to get some details then check the following link.
http://electro-medical.blogspot.com/
Jul 20, 2016 | KitchenAid Dishwashers
How do I reset my Kitchenaid dishwasher that is blinking the clean light 4x
This post is saving me from buying a new dishwasher!! Thank you so much!! It hasn't worked in months
Apr 24, 2014 | KitchenAid Superba Architect II KUDE60FX...
Kitchenaid dishwasher #KUD524SEBLO will fill with water but not run wash cycle. suggestions?
Check this possible causes:
Water-heating cycle
heat,wash,rinse you must check the 3 types. one of them can be the problem, most of the time when water reach the level of heating work o.k , you must troubleshooting the heating elements.
Timer
often fail, in some cycle, they stuck, try to clean the contacts, tight the wires very well, or replace.
sincerely. God bless you
May 05, 2012 | KitchenAid Dishwashers
Dishwasher not emptying after a wash cycle... water flooding kitchen floor.. help!
there is a switch on the floor of the dishwasher, might be dome shaped,lift up on this and see if it is stuck or clogged with gunk
Nov 10, 2010 | KitchenAid Dishwashers
My Kitchenaid dishwasher seems to be stuck on the wash cycle for over an hour. How to I fix this?
Oct 05, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
The "Rinse Only Button" will not function even after going through the "Cancel" cycle.
br, sounds like you have a stuck keypad. This would be the only reason it is switching to a different cycle. Catriver..post back.
Oct 01, 2006 | KitchenAid 24 in. KUDS25 Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
874 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
