AR6L65 wash cycles do not work, only partial cycles function
My washer is brand new. When I set it to one of the wash cycles, nothing happens (indicator lights on orange, door locked light on) but when I turn it to one of the partial cycles instead (lettered A-E) the water runs and drains fine. I'm assuming this indicates that there's nothing wrong with the power or the piping, so I can't think if what else that can be wrong. Please help. Thanks.
  • 236 Answers
SOURCE: door lock indicator will not illuminate- washer will not run
you may have a faulty door interlock?
Posted on Feb 17, 2008
aborcass
  • 2651 Answers
SOURCE: Brand new Front Loader not washing
well if its spinning and not washing, that does sound like aproblem with unit and not what your doing, id call a service company to figure it out, thats why you bought new, not so youd repair it
Posted on Mar 30, 2008
SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
Posted on Jul 09, 2008
  • 107 Answers
SOURCE: Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
Posted on Mar 13, 2009
mgprice
  • 744 Answers
SOURCE: My washer won't complete the final spin cycle. It
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Posted on Nov 09, 2009
The door of a AR6L65 washing machine italy is permanently locked and doesn't allow any function
Most washing machines, do have an emergency door opener. For that you should read in the manual. Sometimes you have to press a little os small key in a hole, Most of the time on the back side. But every machine is different and I don't have a manual of the AR6L65.
Jun 24, 2014 | Washing Machines
My Roper washer will run through wash cycle then stops. Nothing will work for 40 minutes then I can put it on rinse then the cycle will complete. What could cause the stopping with nothing working then...
It could be that the machine is trying to heat the water in the drum, but is not able to for some reason. The timer is waiting for the water to reach temperature before advancing. Posssibly a broken heating element. This can happen even on a cold cycle as most machines prefer to heat all soaping water to about 30C regardless of the temperature setting.
Sep 13, 2013 | Roper Washing Machines
When cleaning the washing machine it stopped and the RL came on. What is RL?
RL means at the start of the CLEANING WASHER cycle a load isdetected inside the drum.
Try removing clothes from drum and start the cycle again.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Top loaing washer fills then mostly empties repeatedly
Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
If it fills and stops, then starts agitation. Repair the drain hose.
Mar 23, 2009 | Kenmore Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mar 29, 2008 | Washing Machines
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Washer only works on spin cycle
Sounds like u need a new control panel
Mar 18, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
