Question about HP Computers & Internet
Can not set screen resolution - HP Computers & Internet
  • HP Master
  • 27,725 Answers
Which operating system ?
Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. Hope this helps.
Posted on Jan 16, 2013
How do I get missing Icons back on my PC screen
The higher the resolution, the more likely you will be able to see your icons.
From Microsoft.com:
1. Open Display in Control Panel. 2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply. 3. When prompted to apply the settings, click OK. Your screen will turn black for a moment. 4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting. Note
• To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display. • A higher screen resolution reduces the size of items on your screen and increases the relative space on your desktop • You can switch your screen resolution temporarily to 640 X 480 if you have games or other programs that are set to run at that resolution. To switch, right-click the game or program (on the desktop or on the Start menu), and then click Properties. Click the Compatibility tab, and then select the Run in 640x480 screen resolution check box. Your display reverts to its default resolution when you close the program. • Your monitor and video adapter determine how much you can change your screen resolution. You may not be able to increase the resolution above a certain level. • Changes to screen resolution affect all users that log on to the computer. • Only the recommended screen resolutions are listed. For additional settings, click the Advanced button on the Settings tab, click the Adapter tab, and then click List all Modes. Select the resolution, color level, and refresh rate you want.
May 28, 2016 | Microsoft CompuRegister POS-1000 POS...
My laptop screen resolution is already set to 1200 *600 and windows 8 does not support in that screen resolution they want to 1200 *768 what can i do
  1. Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
  2. Tap or click Adjust resolution.
  3. Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Screen Resolution in Control Panel shows the recommended resolution for your monitor.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Oct 12, 2013 | Samsung N150 (36725723009) Netbook
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
After being on a few minutes, the text becomes very blurry I lowered the resolution, which makes the text bigger and helps some. There is an internal adjustment, but I don't know where??
Hi hamptonwhh,
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges. Please follow the steps below on how to adjust your screen resolution.
Windows XP
1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
Windows Vista/7
1. Open Display Settings by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Notes : When you change the screen resolution, it affects all users who log on to the computer.
When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution.
Hope it helps.
Thank you for using FixYa.
Jul 04, 2011 | MPC Computers Envision EN 775e 17 in.CRT...
When i put pc on this message comes up on screen saying input not supported and it floats round in a little box.
This generally means you have the display resolution set higher then the monitor can support. To fix this press F8 after you turn the computer on. You may have to press it a couple times before the windows loading screen. A black menu will come up. Select safe mode. Your PC will load into safe mode with minimal drivers and settings. Go to the control panel and select display. Change your screen resolution to something lower then the setting is is at right now. If your screen is 19" or smaller try a setting of 1024x768 for starters. If its 20" or higher try 1280x1024 for starters.
Regards, Chris
Jun 30, 2011 | Acer Computers & Internet
Hi, i own compaq presario CQ42 369TU laptop, how do i increase my screen resolution from 1024x768 to 1280x1024 or higher ?
For Windows XP...
1.
2.
3.
4.
If you cannot set it any higher than 1024x768 and you have already installed the video drivers, that is as high as it can go for your hardware.
May 04, 2011 | Compaq Presario Notebook
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I do not know how to change the resolution size on the screen
please go to desktop properties. select setting option and now you can change your computer resulation.
Aug 11, 2009 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
